Rust
Old Mar 14, 2008 | 07:58 PM
Deridex's Avatar
Rust
Alright, so I've had some rust on the rear driver side wheel well before, but this winter seemed to do a number on it. Now I actually have some gaping holes there. A year ago I patched the one above the wheel well with some body filler, but as you can see, that didn't work too well. My only solution now is welding. I have enough experience with gas, MIG, and arc welding, but mostly on a 1/4'' metal and not on a car body. At the moment I don't own any welders, but I can easily get my hands on an arc welder. Here are the pics of the rust holes. Any advice on how to patch them up would be greatly appreciated.
Old Mar 14, 2008 | 08:06 PM
BenStoked's Avatar
Jesus was a Zombie.
dude, from what i hear, an arc welder is crap for sheet metal. see if you can get one of the others.
the body filler held in the rust, and allowed it to "grow" more than if it were left untreated. the best thing to do is cut the cancer out completely, past the rust into good metal. the rocker pannel would be easiest, because it will not be seen as much, and any possilbe distortion of the metal from welding/heat will be unnoticed.
the fender will be hardest.
if only that were a front fender, id say replace it, paint it. depending on how much a front fender costs in your area, you may consider getting one, if its the same gauge as where the other places need patching. it should have the right shape as the patch needed in the top pic with enough scrap left over for the other spots.
Old Mar 14, 2008 | 09:10 PM
Deridex's Avatar
I donno if I can get MIG, but would oxyacetylene gas welder work? Also, I heard that reversing polarity on the arc welder would give it much less penetration, which is good for thin metal, but I'll have to look into that. But what about the shape of a patch for that hole above the wheel well? Should I just cut it out as a square? Well, anyhow, that's the last time I use body filler.
Old Mar 14, 2008 | 09:53 PM
goon9's Avatar
Sheet metal= Mig
Old Mar 14, 2008 | 11:34 PM
maxima-junky's Avatar
I leave my rust problems to the professionals. I'm not saying you not a pro but ehhh it always comes out so nice when they do it. You know.
Old Mar 15, 2008 | 02:13 AM
Wiking's Avatar
Whatever is done, rust will pop out next year. Contrast that with: "Oily iron never rusts."
After welding the patches, do 'some' spray, check this page
http://www.cardomain.com/ride/748507/17
Old Mar 15, 2008 | 09:35 AM
shoult's Avatar
I've lived in various parts of MI for nearly 40 years (now in NashVegas, TN). One thing I learned is that rust is insidiuous. It is like a cancer. The only way to really beat it, is to never get it.
No matter what amount of rust you THINK you have, you can pretty much double it and call it a conservative estimate.
In order to effectivly remove rust you have to cut it ALL out. That includes inner panels as well as outer panels. You may be able to buy new fenders or quarters, but patches for the inner panels you'll have to make.
As for welding, body work requires a good MIG or TIG welder. OX/Acy is not gonna cut it because it will require to much heat to get good, grindable penatration. Which brings up another point. You'll need access to an exremely good air compressor (read large capacity) to drive the grinders and die grinders you'll need to dress the welds. Your looking at a couple hundred dollars in welding & dressing materials alone to fix that much rust. That's not including replacement panels, filler, paint, etc. Oh, and BTW, your time.
Bottom line is drive your car as is. Every month you can do so, put a car payment in the bank. Save up until you can buy a car (perferably from outside the rust belt). You could even buy another Gen3 Max if you want. But the one you have looks to have terminal cancer. Let it pass.
Old Mar 15, 2008 | 10:39 AM
Deridex's Avatar
Sounds like you've had some experience with that. How much do you figure is it gonna cost for me?
That helps. At least gives me some idea of what to do.
Why would I need a big compressor for a grinder. Why not use an electric one? But, the replacement panels, filler, paint, and definitely time I've got. Money for a new car, however, I do not. For me, it doesn't even have to be that I get rid of rust for good, but rather to hold it off for as long as I can. If I can do that, then I see no reason why she can't last at the very least 5 more years. But thanks for the info, at least now I know what to expect.
Old Mar 15, 2008 | 11:16 AM
Wiking's Avatar
... 5 more years. ...
The issue lies what is now unseen - as shoult indicated. Typically a Nissan with those rust problems in the pic, has wheel wells rusted through, seat belts about to drop on the street, drivers side strut assy swinging in the wind, fuel fillerpipe with holes ... But if theres a mig and time - its cheap to patch. Note: for the wheel well there is a lifetime US-warranty.
My son had just that problem you face. Welded all... bought a cheap spare Nissan with a plastic body-set to hide fender patches etc...
However, before starting try figure all the costs coming next 5yrs - sometimes its cheaper to swap vehicle even with a small loan.
The oil shower will stop all rust immediately. Wheel wells and other parts in direct dirt shower need smtg extra...
Old Mar 15, 2008 | 11:29 AM
shoult's Avatar
Heat and speed. Electric grinders don't dissapate the heat as well as air powered grinder. As far as die grinders? I've seen very few electric ones and I haven't seen one that was worth a crap for body work. Remember, we're talking about HOURS of continual use.
As far holding it off, as you've already found out you can cover over it and make it pretty. It WILL be back, and worse. If you're going to go through the trouble to remove metal and try and take care of the problem them do it right. Half-*ssed attempts to get rid of rust will get you short lived results. Been there, done that, got the t-shirts and scars to prove it.
The idea of just putting a car payment a month (or whatever you can) in the bank is especially important for someone facing a car that may be becoming structurally compromised and has limited monies.
But it's your decision. You can spend your limited resources trying to combat the rust as long as possible, or you can try to get a headstart on something without rust. If you had a blown engine or something mechanical wrong, but with a good rust free body I'd be more inclined to tell you go for it and fix it.
Old Mar 15, 2008 | 12:07 PM
Deridex's Avatar
Well, you don't say? I never knew that.
Alright, I get what you're saying. The problem with me, and probably most people is "if it ain't broke, don't fix it". Until it's too late. But then, as you said, here in the midwest, rust is an epidemic. I've seen people drive cars so bad that you could literally see the asphalt under the pedals. Stuff like that usually just gets covered with a floor mat. Like if you can't see it, it's not there. But we'll see how it goes. Maybe a new car isn't such a bad idea.
Old Mar 15, 2008 | 12:26 PM
Wiking's Avatar
Well, you don't say? I never knew that....
There is, some limits of course ... I dont know but check this:
http://www.cardomain.com/ride/1146109
If you are not in love with the current vehicle [dangerous] make that 5yr plan. Check the wheel wells, thinkabout axleboots, shocks exhaust etc...Calculate what u probably have to put in to keep this rolling, then compare something better available with 5yr scope. There might be a very cheap, low mileage maxima with tranny, engine or whatever just broken... that u may swap. Compare. Anyhow the 5yr plan is sound with tight budget. Whatever u do, put the money into a vehicle that will last that 5yrs. Your work has always value, dont be pessimistic about that.
Old Mar 15, 2008 | 02:24 PM
BenStoked's Avatar
Jesus was a Zombie.
heh, I need to update my cardomain page. I have a vw beetle like this.(project car with no money for...)
Old Mar 15, 2008 | 03:35 PM
augiedog964's Avatar
I would like to see the number 3rd gen maximas left with NO rust at all. There has to be some way to fix it. Yes, that car has a little more rust than most would like to deal with, but on this forum, someone gets a paint bubble and is told to ditch the car. Yes, rustproofing is the best way to deal with it, but it can't be impossible to fix rust. If it was impossible, cars from the 60's would not still be around. Sure it takes work and money, but if we all dumped maxima's because of a paint bubble, there wouldn't be many left...
Old Mar 15, 2008 | 03:36 PM
Deridex's Avatar
Wait, so does that mean they'll buy back the car if the seatbelts are compromised by rust? But yeah, I didn't even think about doing a swap. Come to think of it, the rust is pretty much the only serious problem with it. I just had tranny replaced. I'll bet I could get a rust free but broken 3rd gen somewhere in Colorado, where cars never rust. They have like 0% humidity and almost no rain in some parts.
Old Mar 15, 2008 | 04:23 PM
Mike90SE's Avatar
Mine is rust-free and has over 250K miles. Never seen the salt either.
Old Mar 15, 2008 | 04:32 PM
92gxe/cg2's Avatar
Yes, if the rust is within 1 cm of the seat belts anchors (i think) they have to cut out and replace the metal due to the safety compromizations (is that even a word?). If its not within 1 cm they will just add a support brace or some bs. Iv ebeen reading a couple threads about this (search) and it seems theyll buy your car back if it costs more to fix it than its worth too. Either way they have to fix the rust or buy your car, and if they buy it they have o give ur fair market value, altho you'll most likely spend months haggling with them. I also live in the midwest (chicago) and have a great extremely reliable 3rd gen, but i have much more rust than you I know i have a good amount of rust by the seat belt anchor since it basically moves if u push it, and ive been contemplating going to the dealer to get it fixed/bought but i dont want to spend months arguing with the dealer but when it gets warmer i think il go for it. The recall applies to any 3rd gen, 89-94, not only specific vins like theyll try to tell you. Its a lifetime, unlimited mileage recall.
Old Mar 15, 2008 | 04:47 PM
shoult's Avatar
Those weren't paint bubbles in his pictures. I'll bet if he were to take a small phillips head screwdriver and start poking away at what he thinks is metal around the rust spots he'll find much less metal then he thinks is there. Also, he has a lack of money.
There IS a way to deal with rust. It takes time and money. LOTS of both. You have to remove ALL the afflicted metal and replace it with new, weld, grind, fill, prime and paint. Done right it can look better then new and never rust again. Done wrong or half-*ssed it'll look bad or worse, you'll have only covered it up and it will return with a vengence.
When you try to patch up a rusty car the right way, you quickly come to the realization that rust, much like an iceberg only reveals a small portion of itself. The rest is hidden, waiting to bite your hind end. For example, that little rust spot above the wheel well in the original picture will proably require removing a 4-6" wide strip (maybe more depending on what you find) all the way around the wheel well. You also need to rebuild the inner fender wheel, parts of the rocker inner and out panels, probably the entire bottom of the rear fender and inner.... and it never ends.
I wasn't saying abandon the car. I WAS saying that he should enjoy driving this car while he saves for another. He could EAISLY sink $1000 into repairing the VISIBLE rust that he's shown us. That doesn't even include finish paint work. That $1000 would go a LONG way to finding a better, rust free car, even a better example of a Gen3 Maxima.
BTW, with 50s & 60s vehicles selling for $20K to $1.5M it is MUCH easier to justify the time and money to repair the rust. But you can buy a low mileage, rust free, SE, 5spd for WAY less then $20K if you look. I've seen restoration shops replace almost every panel except the VIN plate on a supossedly "solid" car.
Old Mar 15, 2008 | 05:08 PM
jonmandude's Avatar
If the only area(s) you have that are rusted are the ones in the picture, it could be worth doing the work.
If there is a lot more,then what these guys are telling you is sound advice. Unless you are deeply attached to your car, or it holds some sentimental value, it is not worth the money to fix. I bought a completely rust free '90SE with high miles for $1500. If yours is mechanically sound, you should be able to find a similar deal, or even better for a non running shell. Then spend your time on swapping drivetrain. You will be much better off in the end.
Old Mar 15, 2008 | 05:14 PM
Deridex's Avatar
It's not exactly a paint bubble, but it's not the end of the world either. Guess I'll just use bathroom caulk or something until I can get my hands on another 3rd gen body.
Old Mar 15, 2008 | 05:23 PM
Greeny's Avatar
¯\(°_o)/¯
Use this instead of bathroom caulk
Old Mar 15, 2008 | 08:19 PM
Deridex's Avatar
That'll work.
Old Mar 15, 2008 | 11:52 PM
Wiking's Avatar
Wait, so does that mean they'll buy ...
Check the wheel wells, take bright light, peek under upholstery... T-here was a long thread where mr 'Don Quixote' (who ? was he, mem fails) went through the exercise against fortress Nissan. Where is it now? ... anyways with patience you may get it fixed or some compensation. Take the money (if any) and DIY; it is costly affair to repair it decently. However, its under upholstery and I think there is no need to show it around - just weld enough add on scrap metal.
I am not pushing anybody to any direction but to do just what you suggested: 5yr plan... and that starts from evaluation. You may weld the chassis and it can serve for decades (oiled). The outside paint I have not never seen one used vehicle which will not start flowering during 1-2 yrs after most pro surface job. Rust just wont stay idle... This is because in micro level there always will be left some cavities (=moisture nests). Always means all ways... These cavities will become under enormous forces sun baking, winter freezing and whatever bumping, kicking... and burst, maybe first unseen, next...
Best job I got was with my 11½feet high RV: sandblasted the whole 6ton elephant, bought/sprayed most expensive primers, then the top ten feet stayed ok for 10 yrs... on the places that had never been welded and/or not had seams.
Old Mar 16, 2008 | 06:43 AM
goon9's Avatar
I think you on to something, I never thought of something like that. I'm getting ready to smooth out between the wheel well seems. I may try that.
Old Mar 16, 2008 | 03:18 PM
Greeny's Avatar
¯\(°_o)/¯
I used this stuff on my rocker panels(under rear doors) after i cut out all the rust spots, just built up the holes with it, let dry, sand smooth and paint.
Old Mar 16, 2008 | 03:44 PM
shoult's Avatar
But we both live in an area where you can pretty much leave bare metal out and it will only surface rust after two years. Geography has a GREAT deal to do with things here. Do the same thing on a car in GR MI (part of the rust belt) and it'll spit that patch out in a year or so.
Old Mar 16, 2008 | 03:57 PM
Greeny's Avatar
¯\(°_o)/¯
I realize this stuff will not last forever, especially in the northern states, but if you red the op's last post, he said he was planning on stuffing some bathroom caulk in the hole, then look for another car..I simply gave him a better option that will last longer then his idea, and look a little better.
Old Mar 16, 2008 | 07:36 PM
Deridex's Avatar
Hey, you'll be surprised how many things you can do with bathroom caulk. But I was OBVIOUSLY kidding about using it on my car.
Old Mar 17, 2008 | 06:41 AM
internetautomar's Avatar
mod or sell?
I used some on the center tail light panel on the I30
Old Mar 17, 2008 | 12:51 PM
Deridex's Avatar
A ha! So I'm not the only one then. I meant about using it on the rust. But I once used clear caulk to reattach my whole OEM spoiler. Worked quite well. Can't even tell it's there. Holds even at 80 m\ph.
Old Mar 17, 2008 | 02:34 PM
Greeny's Avatar
¯\(°_o)/¯
I thought you were kidding about using bathroom caulk?
Old Mar 17, 2008 | 03:49 PM
mod or sell?
it kept the water out
Old Mar 17, 2008 | 03:57 PM
Deridex's Avatar
I said that about my actual car. My parts car, however, I'm free to experiment with anything I want.
That would be the reason they call it BATHroom caulk.
Old Mar 17, 2008 | 04:03 PM
shoult's Avatar
I don't see any parts, let alone a parts CAR!
Old Mar 17, 2008 | 04:15 PM
Deridex's Avatar
It took space in my garage, so after I removed the tranny (which was the only part I really needed at the time that I bought it), I butchered that thing, keeping the engine, rear disk breakes, and a whole bunch of small stuff like window motors, sunroof, electronics, wheels, interior, etc. The picture is of how it looked a week before I chopped it up and drove it to the scrap metal facility.
Old Apr 16, 2008 | 01:00 PM
projectviper255's Avatar
WOW allot of parts were taken from that bad boy
Old Apr 16, 2008 | 01:19 PM
goon9's Avatar
BAN THE *****! Stop the wasted cyber-space!
Old Apr 16, 2008 | 02:17 PM
1992maximase30's Avatar
hey deridex and everyone else....you see that rust by the front strut assembly?
i've been the the junkyard and seen a few of those where it rots out there was even one where there's a long crack.
makes me wonder bout mines....
does anyone know if thats a recall and does anyone have the crack/rotout around that area...
Old Apr 16, 2008 | 07:31 PM
mod or sell?
oddly enough rusted out strut towers do not qualify for a recall.
if they did, chrysler would be in deep doodoo. the 96-07 caravans have been known to rust out within a couple of years.
Old Apr 16, 2008 | 07:50 PM
that sucks.
brian as many 3rd gens you had you ever noticed this?
my ve had one...very wide.
