VG30E fuel injectors and distributor
Old Mar 24, 2008 | 06:54 AM
G3Karl's Avatar
Does the VG30E (my '92 gxe) use sequential fuel injection? I replaced one of my injectors and the car now runs like crap under 3K rpms. It use to bog under load under 3K with the old injectors and have a obvious miss. Now the car runs smooth but under 3K it is a dog. Also over 25% throttle and its sluggish. I think the other injectors need to be replaced since this is the only thing that changed.
Old Mar 24, 2008 | 07:33 AM
internetautomar's Avatar
mod or sell?
were they rebuilts?
Old Mar 24, 2008 | 09:37 AM
Wiking's Avatar
How many miles logged for plugs, wires, cap, rotor, distr gnd clean...?
See http://www.cardomain.com/ride/748507/12
Old Mar 24, 2008 | 10:05 AM
Pearl93VE's Avatar
I can has?
How is Idle?
Old Mar 24, 2008 | 10:10 AM
G3Karl's Avatar
Originally Posted by Pearl93VE
How is Idle?
idle is smooth and revs freely while in drive/neutral. It only bogs down under load. Over 3K the car runs smooth. Under 3K or over 25% throttle it bogs down. The injector is one of the originals that I sent for cleaning/rebuild. I did replace the wires awhile ago but not the plugs.
Old Mar 24, 2008 | 10:13 AM
G3Karl's Avatar
were they rebuilts?
sorry for the misunderstanding but i only replaced one injectors with a factory rebuild. I really dont think its the injectors, but think that its something else. Just cant put my finger on it. Car runs/revs smooth in par/neutral, its only a dog under load whild driving under 3K rpms.
Pearl93VE's Avatar
I can has?
I had the same problem in my VE. It turned out to be the Coolant Temperature sensor. (ECTS) It may be worth checking out since your description sounds as mine did.
Here is the thread for more information on it:
http://forums.maxima.org/showthread....nt+temperature
Old Mar 24, 2008 | 12:09 PM
G3Karl's Avatar
I dont wanna start thowing parts at the car. How can I test the ECTS? My fuel mileage does suck, so this "may" be the problem.
Thanks.
*edit*
when the car is cold it runs fine, just when it warms up....
hummmm..
Old Mar 24, 2008 | 12:36 PM
Wiking's Avatar
Originally Posted by G3Karl
... I did replace the wires awhile ago but not the plugs.
Typical... Start from there: Plugs, wires (I MEAN REAL WIRES), Cap, Rotor, then do Ground the distr.
Old Mar 24, 2008 | 12:47 PM
G3Karl's Avatar
I didnt do spark plugs because they looked good when I pulled them awhile ago. I am confident it is either the injectors or possibly the ECTS.
Anyone know how to test the ECTS?
*edit just found out how to test the ects*
Old Mar 24, 2008 | 01:00 PM
Pearl93VE's Avatar
I can has?
Disconnect The ECTS Wire Harness. Use a multimeter on it's lowest OHM setting (Should be like 0-100 or something) Touch each pin on the multimeter to each terminal in the ECTS plug (Not the wiring harness, the plug itself)
70 Degrees = 2.1-2.9 Ohm
122 Degrees = 0.68-1.0 Ohm
177 Degrees = 0.3-0.33 Ohm
Most ECT's when they go out read very high meaning they are stuck open. Mine on the other hand (And Probably yours) Will be stuck closed and have a very low/ No Reading. Causing the symptoms described.
Also, they're only $30. So this would be considered a tune up item in my eyes.
Old Mar 24, 2008 | 01:13 PM
Wiking's Avatar
What on earth is your ECTS?
Such an acronym is not in the whole FSM.
Old Mar 24, 2008 | 01:16 PM
Pearl93VE's Avatar
I can has?
Engine Coolant Temperature Sensor...
EF&EC-143
Old Mar 24, 2008 | 01:41 PM
Wiking's Avatar
EF&EC-143
Yes thank you. Engine Coolant Temperature Sensor... ECTS - not there.
Old Mar 24, 2008 | 01:51 PM
Pearl93VE's Avatar
I can has?
Old Mar 24, 2008 | 03:08 PM
G3Karl's Avatar
im going to pick one up after work tonight and put it on. Hopefully its it. if not, i'll consider it a tune up part.
I got the hayens manual, but where is it located on the VG30E model? Just incase the haynes is incomplete.
Thanks!!!
Old Mar 25, 2008 | 06:18 AM
Wiking's Avatar
pic
That proves youre ECTS -right!
Old Mar 25, 2008 | 07:14 AM
G3Karl's Avatar
i put a new ects in. How many are on the VG30E? Im assuming its the sensor by the radiator hose/bypass hose by the thermostat assembly, on top of the motor?
I replaced it and the car runs alot better. Still sluggish under 3K though. Im going to clean my throttle body out and get all the carbon buildup off. Im also going to swap in the new injectors too.
Old Mar 25, 2008 | 07:24 AM
gapboi210's Avatar
The car running badly when it is warmed up? This couldn't be an o2 issue? Sounds like something to do with it going into closed loop.
Old Mar 25, 2008 | 09:19 AM
Alex_V
My friend once told me he fixed the oil pressure sensor wire on his VG-auto and his idle smoothened out, and he gained some low end power. And his car was running "perfectly" before. So you might want to check and see that the wire is still connected and the sensor isn't falling apart. I'm going to replace mine since my car had alot of weird stuff loose and or not there from the previous owners.
~Alex
Old Mar 25, 2008 | 09:54 AM
G3Karl's Avatar
Bingo. Car runs like a champ when cold. As soon as it warms up, runs like crap under 3K or over ~25% throttle. Sounds like a closed loop issue. I was hoping the ECTS would have taken care of it. Im sure its the original one. Proabbly it since my gas mileage sucks. Where is the o2 osensor n these cars?
Old Mar 25, 2008 | 09:55 AM
G3Karl's Avatar
~Alex
Do you have a picture of where this is located? I think its on the back of the motor, nearest to the firewall?
Old Mar 25, 2008 | 09:56 AM
G3Karl's Avatar
oh, and im assuming the VG30E only has one ECTS?
Old Mar 25, 2008 | 09:57 AM
gapboi210's Avatar
have u tried pulling codes?
Old Mar 25, 2008 | 10:00 AM
G3Karl's Avatar
No, how do I do that? My service engine soon light does not come on while driving.
Old Mar 25, 2008 | 12:18 PM
G3Karl's Avatar
one more question. Where is the o2 located?
Old Mar 25, 2008 | 12:24 PM
Pearl93VE's Avatar
I can has?
On The Y-Pipe, Just before the catalytic converter.
Old Mar 25, 2008 | 12:43 PM
gapboi210's Avatar
they won't always throw a CEL if there is a code (seems espcially true on OBDI) here are the instructions
http://forums.maxima.org/showthread.php?t=399534
the pics are gone. You can get to the ECM on the passenger side floor in front of the center console below the stereo. There is a little plastic access panel.
Old Mar 25, 2008 | 03:32 PM
G3Karl's Avatar
how many o2 sensors? I checked autozone.com and they say two....one before the cat. converter and one after.
Old Mar 25, 2008 | 03:34 PM
Greeny's Avatar
¯\(°_o)/¯
I still see the pics.
Old Mar 25, 2008 | 04:38 PM
1992maximase30's Avatar
there's one o2 sensor before the cat but after the flex pipe....my bet is on the knock sensor.
john,brian, and a couple others told me it could be the knock sensor...did'nt have a code for it till later.
then brian gave me a way to "bypass" the knock sensor...and BAM i had me low end.
even though i had the ve but i'm sure it applies to the vg too.
and btw, yes your engine has multi-port sequential fuel injection.
unless one of it's important sensors are'nt working properly...then it just switches to multi-port injection.
Old Mar 25, 2008 | 04:50 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
that's because they're retarded. 3rd gens have one 02 sensor.
Old Mar 25, 2008 | 04:56 PM
BenStoked's Avatar
Jesus was a Zombie.
but they make such quality parts! how could they have this wrong???
Old Mar 25, 2008 | 05:28 PM
gapboi210's Avatar
oops sorry maybe i couldn't see pics due to the firewall @ work
Old Mar 25, 2008 | 06:37 PM
sometimes it's better to just rip the bandaid off... and let the truth come and hit you like a
Old Mar 26, 2008 | 11:30 AM
G3Karl's Avatar
well I replaced the o2 sensor today and wah-lah....car runs *almost* perfect. The o2 sensor that I took off was in bad shape.
I got the new injectors today. I will proabbly put them in on saturday or sunday.
Are there any other sensors on this car I should replace? So far ive replaced the ECTS and o2.
Anything else? I've also flushed the cooling system, new radiator hoses and had the a/c recharged last year. Im getting ready for the summer driving season and dont want any problems.
Old Mar 26, 2008 | 11:31 AM
G3Karl's Avatar
where is the knock sensor located?
Old Mar 26, 2008 | 11:33 AM
shoult's Avatar
Did you get the AC recharged with R-12 or have you converted to R134a?
Old Mar 26, 2008 | 11:42 AM
Pearl93VE's Avatar
I can has?
knock sensors usually don't cause many problems for VG's, I forget the exact location in them as well. I assume you have replaced your fuel filter as well?
Old Mar 26, 2008 | 12:12 PM
mod or sell?
vg knock sensor is on the side of the block by the rear exhaust manifold.
that's part of the reason it is useless
