Guide Pin Trouble
Old Mar 27, 2008 | 06:00 PM
92gxe/cg2's Avatar
Guide Pin Trouble
I didnt want to thread jack the other brake thread, so here goes.
A while back, i noticed my brake power wasnt what it used to be, and i had a leak coming from the ABS modulator, so i figured theyre probably related. I replaced the ABS modulator and bled all the brakes with a friend and it seemed better. I went to test the brakes (abs needs a front sensor and the bolt is blocked by the sensor wire and in a very awkward spot, has anyone got any tips for removing the front left sensor?) so i went to lock the brakes up and only the fronts locked up. Turns out my rear guide pins were rusted, alot. So i took them out, sanded them with a wire wheel, and greased them like no tomorow. The only problem was, after i put it all back to gether i realized the boots were cracked, so i figured i had little time until they rusted again.
So i went to test them after fixing the pins and bleeding the brakes, and the e brake seemed much ebtter, but still, the rears dont lock up. With the ebrake pulled they do, suggesting the hydraulic pressure isnt enough to lock them? I put the car on a lift, and spun the backs tires by hand and applied the brake and they slowed/stopped.
So the back brakes are not getting enough stopping power, could it be guide pin or possibly a stuck piston? I understand the cracked boots may have caused the pins to rust up again, being in chicago, but i doubt they would have rusted shut within a day, so im thinking it could be a seized piston, or possibly still related to the pins, any suggestions? Any way to test these items?
Old Mar 27, 2008 | 07:34 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
well lockup is never actually a good thing... and the rear brakes are naturally weaker than fronts to avoid massive lockup from balance differences. so are you SURE it's a problem?
Old Mar 27, 2008 | 07:48 PM
92gxe/cg2's Avatar
I understand the whole lock ups not good, hence abs being an option, but when braking, i can feel the fronts doing all the work and a good amount of nose dive. when holding the e brake halfway and braking i can feel the rears sort of diggin in as they brake and nosedive is reduced. And the rears get the brake fluid pressure before the fronts (granted only for a split second, or is that only on rear drum brakes, yeah i think thats it) But either way they are getting less braking pressure and its not good, also something i wanted to mention in the first post, my bad, is that the pedal goes all the way to the floor when im stopped, altho not toooo easily, but the fronts lock before i hit the floor when driving. A friend once told me his pedal did the same until he freed his frozen guide pins in the front.... hmm..
Old Mar 27, 2008 | 08:13 PM
1992maximase30's Avatar
your car more than likely comes equipped with...well i forgot the name.
but heres what it does
these devices are mounted on your rear subframe tied within your braking system and has a little link attacted to the trailing or parallel arm.
when there's very little load in the back certain amont of fluid is let in...hence why your rears don't lock up.
but if there was about one or two people in the rear then they would've locked up.
thats why mines locked up...cause i have a whole lot of junk in tha trunk.
Old Mar 27, 2008 | 08:20 PM
load sensing valves. basically the idea of the LSVs is to allow more fluid pressure when the back is heavier-loaded. that way more weight means more grip and more grip means you can brake harder without locking up. check out the front guidepins tho b/c stuck front brakes can perhaps make the front bias increase. other than that i dunno what to say since i don't have rear discs, and my brakes are absolutely worthless overall.
Old Mar 27, 2008 | 08:21 PM
92gxe/cg2's Avatar
Lol, Oh Stillman. Thank you for the input, but I believe these valves were ONLY on the 92-94 SE's with ABS, and they are very rare. I am pretty sure i dont have them as ive checked before, but saw nothing. But then again im not 100% sure.
Old Mar 27, 2008 | 08:40 PM
i saw some at a JY recently. i forgot where tho. maybe on the car i took my VE struts from or something.
Old Mar 27, 2008 | 09:04 PM
BenStoked's Avatar
Jesus was a Zombie.
my 91 se has 'em
Old Mar 27, 2008 | 09:10 PM
92gxe/cg2's Avatar
Hmmm, odd. Maybe i read or heard wrong, maybe theyre on my car, i got work in the next couple days and other things tying me up, but perhaps il inspect this closer, or put it on the lift at school to see whats really what. If I do have them, ive heard they are rare, and also that they are bypassable...Hopefully its something simpler, like a bad caliper. Time will tell. Ive got a parts car with perfect brakes, it had a $250 brake job done to it before i got it, so i could always try switching just about everything out since its the same trim/year. Except my tools are quite limited. Anyone else know anything about these LSVs?
Edit: Ben, i now see your pic, maybe i wasnt looking far enough into the subframe or w/e to see them, il have to check. Perhaps i can adjust them with those bolts, if mine arent rusted to H***
Old Mar 27, 2008 | 09:52 PM
they're up there.
so you probably did'nt pay attention to em' or either you have abs with dps
Old Mar 28, 2008 | 01:54 AM
Wiking's Avatar
I guess all 3gen maximas have the double LSV's. (Double as our suspension is independently superior to 4,5th gen cart axle.).
U may adjust both LSV nuts. Try rotating [both] one turn at a time, then testing until brakes are what u want em to be... Or you may do as FSM tells, check pressures and adjust.
FSM; with added 1300lb rear =trunk load, measured brake fluid pressure should be:
- front pressure 710psi , rear 550-700
- front pressure 1400psi , rear 740-940
ABS computer pins do lose contact, check out. Run the self diagnostics to test your sensors...
http://www.cardomain.com/ride/748507/18
Life is like this w/o maintenance
Old Mar 28, 2008 | 06:01 AM
internetautomar's Avatar
mod or sell?
according to the 92 fsm only VEs with ABS got the LSVs. my VE w/o ABS didn't have them. and I haven't stooped to getting a VG so I don't know about them
Old Mar 28, 2008 | 06:14 AM
BenStoked's Avatar
Jesus was a Zombie.
so far as i know, the info ive given(91 se 5-speed, lsv) are all stock on my car... but i dont own a ve and i have 'em. (but i do have abs. maybe its an se thing?)
Old Mar 28, 2008 | 01:17 PM
any thoughts on putting LSVs on a non-ABS car?
Old Mar 28, 2008 | 02:15 PM
92gxe/cg2's Avatar
thats what they should have done, since the non abs rears can probably lock up no problem, itd be nice to have the LSVs in there, we dont much need them do we? Either way our abs keeps them from locking, but then again the non abs car ppl didnt pay for abs when they bought it new from nissan, so nissan probably figured, forget them.
Old Mar 28, 2008 | 02:26 PM
then i guess i'll be peeking under the ****-end of all the 3rd gens at the local JYs and see if i can nab some. tho... that may require re-running some brake lines. i'll examine that when i get to that point.
Old Mar 28, 2008 | 09:56 PM
it won't require re routing but it will require some cuttin and adding new fittings.
Old Mar 29, 2008 | 12:23 AM
Wiking's Avatar
- lets you to adjust the balance between front/rear
- automatic compensation when loads change
If you havent got bigger issues, why not? Will you/anybody notice it - who knows ... possibly saves your gf from spin in an slick emergency situation.
Old Mar 29, 2008 | 06:42 AM
but i dunno how to do that ... not on a flared precision fitting of that sort. you sure that's the easier choice, rather than taking both metal brake lines from mc-LSV, and LSV-caliper?
Old Mar 29, 2008 | 06:49 AM
my car is my girlfriend... she's the only one that gets me
ibsomeonereplieswiththe007smiley
well ya, of course i'd want my 'bigger issues' out of the way. But once i get the transmission situation resolved for good, i'm going to start on the super-overhaul of my suspension and brakes. ALL new bushings (fLCA, rLCA, PLinks, SB-to-frame, SB end links, PS rack), new BJs, swap for SE springs/sways, KYB all around, and a FSTB just for kicks.
AND THEN i'm doing a full brake treatment. HawkHPS all around w/ brembo rotors (maxima fronts, z31 rears) w/ LSVs.
and then i'm going to take a big deep breath.
Old Mar 29, 2008 | 08:43 AM
Wiking's Avatar
but i dunno how to do that .....
Theres a flattin /cutting tool set for brk lines, 20$ ? ... you may practice with spare line, after 5min youre pro.
Old Mar 29, 2008 | 09:06 AM
BenStoked's Avatar
Jesus was a Zombie.
since you asked nicely
Old Mar 29, 2008 | 07:02 PM
oh yea trust me.
from the mc the lines are fitted and routed on the car then routed under the lift point then routed i belive over the gas tank, but for sure routed over the rear subframe. then to the lsv's then routed to the calipers.
Old Mar 29, 2008 | 07:35 PM
maxitech's Avatar
Still faster than your Subie...
Old Mar 30, 2008 | 07:42 AM
mod or sell?
you sure
Old Mar 30, 2008 | 08:34 AM
maxitech's Avatar
you sure
Wanna race?
Old Mar 30, 2008 | 10:03 AM
mod or sell?
Wanna race?
sure. at the track of course
Old Mar 30, 2008 | 10:07 AM
maxitech's Avatar
Of course. Then again, I'm pretty sure my VG is at least a bit faster than stock and quite a bit faster than all those poor autotragic GXE's.
Old Mar 30, 2008 | 01:07 PM
mod or sell?
a bit faster doesn't say much
Old Mar 30, 2008 | 03:17 PM
maxitech's Avatar
Alright, significantly faster than...I was trying to be modest. The VLSD with its shorter 1st and 2nd gears will help out, too.
AaronL
Nov 15, 2020 11:52 AM
kjlouis
Oct 3, 2015 05:29 AM
zmcneely13
Sep 26, 2015 02:26 PM
nissan99
Sep 11, 2015 03:52 AM
beerman1378
Sep 8, 2015 02:19 PM
