Fuel Injector Wire Harness
Old Apr 22, 2008 | 03:33 PM
raeqwon28's Avatar
I'm need of some help. I did an engine swap with a Japaneese Import Engine and everything is runing ....but its running on 3 injectors. The reason its not working all 6 is due to a pin missing in(I belive) the female harness that is connected to the firewall(The big wireharness that runs to the firewall). I tried looking for my old fuel injector but had already scrap the old engine. Looking for the pics is there anyway I could add a female slot inside this wire harness or is there any adapter that could work?
This is a view of the fuel injector wire harness male pin side
This is the fuel injector wire harness
a view of the female side of the fuel injector wire harness this runs to the firewall
Excuse the bigs pic. any help would be greatly appreciated.
Old Apr 22, 2008 | 04:29 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
what wire colors are coming off each plug? that's so weird for it to be missing, yet all 3 have 2 wires each coming from them?
Old Apr 22, 2008 | 04:39 PM
internetautomar's Avatar
mod or sell?
easy way = hard way.
this is why you swap everything over from your OLD engine
Old Apr 22, 2008 | 07:31 PM
Hectic's Avatar
Japaneeeeese
Old Apr 22, 2008 | 07:33 PM
raeqwon28's Avatar
1 plug has a red wire with black strip and a white wire with a red strip
2 plug has a red wire with a blue strip and a white wire with a purple strip
3 plug has a red wire with a yellow strip and a white wire with a green strip
Old Apr 22, 2008 | 07:41 PM
that's kinda weird to have 6 colors and just 3 pins at the plug. what colors are the wires on the harness-plug end?
Old Apr 22, 2008 | 07:53 PM
raeqwon28's Avatar
At the plug end white with red strip, red with blue strip, red with black strip and red with yellow strip
Old Apr 22, 2008 | 07:55 PM
oops i meant the one with just 3... so i guess that's the car-side plug. i'm assuming your white/x one is missing from the car-side which is the power to the injectors. ECU pulls grounds.
Old Apr 22, 2008 | 10:04 PM
Wiking's Avatar
I'm need of some help. ...
Me too. My horses were exhausted running to-an-fro the whole gymnasium wall (where the pics were projected)... but maybe I got ALL the PIGS.
Solder-in-Solution. Its not forbidden or shameful to cut and paste wires...
Old Apr 23, 2008 | 08:04 AM
mikekantor's Avatar
I think thats the ground for the injector signals, they share the same one. Slip out the male and see if you can ground it. They come out when you put a very tiny screwdriver inside and press on a tab, look up the 9007 headlight swap because there is a similar technique used there.
Old Apr 23, 2008 | 09:43 AM
raeqwon28's Avatar
I think I follow you. I'm going to look up the schematic in the manual and try your suggestion
Old Apr 23, 2008 | 09:52 AM
actually it's a +12v from the IGN, and the unique-to-the-injector wires are individual grounds. that's why i said that our ECUs pull grounds rather than pushing voltage. one wire provides voltage for 3 injectors and the ECU is at the end of the current-flow rather than the beginning.
Old Apr 23, 2008 | 06:13 PM
Soaknfused's Avatar
I would hook everything up and probe those three wires for 12v and see if any are hot. I would venture to guess that they will not be, in which case you can simply provide an ignition switched +12v supplied to the injectors as previously stated and all should be well if those existing 3 wires are indeed the individual grounds for the 3 non-firing injectors.
9aj9
Apr 5, 2020 12:11 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
