gasket for IACV
Old May 13, 2008 | 07:22 PM
maximaman1313's Avatar
gasket for IACV
I took off my IACV or idle control unit. on my VE auto. I looked on courtesyparts and schmucks for a gasket it for it, the one on there isn't in good shape. anyone know where to find one?
more im looking at it, it actually looks like maybe a gasket sealant? anyone know what to use so i can put it back on and not have air leaks?
Old May 13, 2008 | 08:13 PM
cachejob's Avatar
you can get an IACV gasket through your local dealership. when i did mine it only cost $10.25 through the dealer. i didn't know part # so i just asked for the IACV gasket. in the following thread mikekantor lists the VE IACV gasket part # as 23785-97E00.
http://forums.maxima.org/showthread....ht=gasket+iacv
Old May 13, 2008 | 08:26 PM
just tried to search by that part number, nothing came up.
Old May 13, 2008 | 08:29 PM
ustfdes's Avatar
- Product of Maxima.org -
ibgasketpaper?
Old May 13, 2008 | 08:33 PM
Originally Posted by ustfdes
ibgasketpaper?
ive never done before. do i just get some at a parts store?
can I just use a silicone sealant?
Also would a bad Idle air control unit cause motor to have a constant high idle? screw is turned almost all the way clockwise, car fully warm, and idle is about 900. when i turn it a few turns counterclockwise, it jumps to 1600rpms idle. again fully warmed motor.
I thought idle with the screw almost full clockwise would be around 700rpm, and i didnt think just a few half turns counterclockwise would cause a jump to 1600rpm.
Old May 13, 2008 | 08:34 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
ibgasketpaper?
i'm parting out (?) a roll of gasket paper. I can give you a square in an envelope if you want..... $1.50 shipped
Old May 13, 2008 | 10:02 PM
Wiking's Avatar
Originally Posted by maximaman1313
...can I just use a silicone sealant?
Yes. (Dont let it spread inside.)
Idle adjustment is done with ECU program III; see FSM EF&EC 29
IACV opened http://www.cardomain.com/ride/748507/4
Old May 14, 2008 | 10:40 PM
ustfdes's Avatar
gasket paper is what i had to use on my throttle body, because i couldn't get a gasket in time (VE parts are hard for me to find...)
and it worked just fine, i just cut it to fit (as perfect as i could get it) and then i used RTV on both sides, but will be removing it shortly to install my phenolic spacer kit (Thanks Aaron!)
Old May 15, 2008 | 06:27 AM
xx-Marshall-xx's Avatar
kthxbye2u
RTV is working perfectly for me.
knight_yyz
Nov 1, 2015 01:34 PM
Gingerheadman
Oct 1, 2015 05:11 PM
junito1
Sep 23, 2015 12:14 PM
bumpypickle
Sep 20, 2015 08:22 AM
