Cabin Heater Control Valve Assembly (Wiki)
Old May 22, 2008 | 09:53 PM
1993-VG30E-GXE's Avatar
Wiki, got a question for you buddy:
REF. PAGE 8 YOUR NISSAN MAXIMA GUIDE - 748507_460_full.jpg (Assembly JPEG) -->VACUUM LINE FROM INTAKE 15. - HOSE CONTAINS SMALL ONE WAY VALVE
I Dropped this one way valve somewhere in the void, and I can't find it. When I go to replace hose 15. , can I do without this valve and just create 1 long hose from the intake to the assembly?
Old May 22, 2008 | 09:56 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
you're gonna need that valve. that valve is to maintain vac hold even when the engine is at a not-very-vacuumish condition (like WOT or off). i have a spare SOMEWHERE but i forget where i put it, so you may as well go to a JY and nab one.
Old May 22, 2008 | 11:18 PM
OK cool - by the way is it a generic part or do I need Nissan OEM? It's just called a ONE WAY VALVE?
By the way are Gates Rad Hoses OK? The lower molded one I found was Michelin I think. Do they all meet the spec?
Old May 22, 2008 | 11:40 PM
Wiking's Avatar
Your coffee brewer has got one ... dont tell mama what happened
Spec? I use only blk...
Old May 23, 2008 | 12:15 PM
Which direction should I point replacement valve
ARROW POINTING AWAY FROM INTAKE
or
ARROW POINTING TO INTAKE
Old May 23, 2008 | 12:23 PM
or
air should flow into the intake from the firewall side. if the arrow goes how i think it should, then the arrow would point at the intake. that way the intake can pull vacuum, and the one-way valve will hold it in place.
msellas
Sep 23, 2015 09:16 PM
homeofbacon
Sep 23, 2015 07:17 PM
bumpypickle
Sep 19, 2015 01:07 AM
tardrex
Sep 11, 2015 07:35 PM
dcam0326
Sep 7, 2015 07:26 AM
