cruise control
Old May 27, 2008 | 08:16 PM
DBooker_93GXE's Avatar
cruise control
just a random question, my cruise control doesn't work, the only thing that does work is the little green light that comes on when u push the button, and thats the light on the button lol, i switched the relay fuse things under the hood to see if that was the problem but that wasn't it, are there anyother ideas why it doesn't work (the cruise light on the dash doesn't turn on at all either...just the light on the button)
Old May 27, 2008 | 09:45 PM
Wiking's Avatar
Originally Posted by DBooker_93GXE
....just the light on the button)
Cracked hose? Check the link how to tst the pump.
Old May 28, 2008 | 05:21 AM
shoult's Avatar
Does your horn work?
Yeah I know that's a weird question, but I found that the two share the circuit from the steering wheel. They share a fuse. If your horn works then the fuse is okay.
Old May 28, 2008 | 05:44 AM
Obsession_92-94's Avatar
You could try checking the switch from the steering wheel and see if there is a continuity break there.
Old May 28, 2008 | 09:05 AM
Cliff Clavin's Avatar
Way out West
When I first got my car, the cruise didn't work. I got the entire CC assembly that's under the hood from a junkyard and swapped it in and no problems since.
It was the part with the green sticker on it in the pic (not sure it's the same on the VG, but should be similar):
Old Jun 1, 2008 | 05:12 PM
yeah my horn works....and check the wiring in the steering wheel? how exactly would i go about doing that, I have a spare steering column and tried to play with it on that and couldn't quite figure it out....but of course the steering wheel was locked to tho lol
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
