Max cutting off
Old Jun 16, 2008 | 01:20 PM
majordan's Avatar
Max cutting off
The Max cut off two times in traffic on its own, any ideas on what cud be the problem. This is the first time this has happened.
tks
Old Jun 16, 2008 | 01:29 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
tks
you have a 19__ Maxima (SE or GXE?) with a _____ transmission?
how fresh are your plugs (all) and cap, rotor, and wires (vg)? are you throwing any codes? have you checked EVERY single electrical connector under the hood for green corrosion crap, and cleaned it? all good things to check.
Old Jun 16, 2008 | 02:37 PM
internetautomar's Avatar
mod or sell?
Bad grounds?
bad coils?
Old Jun 16, 2008 | 03:11 PM
majordan's Avatar
I have a 91 Maxima Auto tranmisssion. Grounds and Coils?
tks
Old Jun 16, 2008 | 04:18 PM
mod or sell?
I'd check grounds, you don't have a VE so only 1 coil.
Old Jun 16, 2008 | 08:55 PM
also check battery terminal tightness. i had a loose positive cable cause my car to shut of uphill at night (like... everything died, no lights, no NOTHING) so i had to yank the handbrake, wait for the lane to clear, get out, tap the cable and pull into the parking lot near me. sometimes it would restart with the loose cable (before i figured out what was wrong), but once the whole car conked out, i figured out it was the battery cable being loose.
Old Jun 17, 2008 | 01:17 PM
majordan's Avatar
I will check the battery terminals for tightness, as far as the grounds go what and where should look?
Old Jun 17, 2008 | 01:36 PM
there's one on the distributor, 2 on the backside of the upper intake manifold, 1 on the tranny, 1 under the car on the catalytic converter brace, just to name a few.
Old Jul 4, 2008 | 10:10 PM
maxim90's Avatar
Same here....and Im freaking baffled.
Mine quits while driving, then will not restart for a period of time. There seems to be no rhyme or reason for this at all. I come back the next day and restarts fine most of the time. I get NO FIRE out of the coil but I have 11 volts to the coil with ignition switch in the "on" position. I have put in 3 different distributors....(Crank sensor) 2 different ignition modules, 3 different coils, and tried 2 new coil wires. and no matter what I do, it's the same thing. No spark out of the coil
I'm sure it's something stupid and small.......I just cannot find it.
Old Jul 5, 2008 | 08:39 AM
have you checked your ECU's codes? also check for corrosion in various connectors. and check your "engine cont" relay
Old Jul 5, 2008 | 09:41 AM
maxim90's Avatar
I have checked for corrosion in all the connectors....(injectors, ignition plugs, etc.) I DID try and read the codes on my ECU but i'm not sure i am interpreting them properly. Could I get some good instruction on how to read those codes?
Im going to check the ENG CONT relay now....
Old Jul 5, 2008 | 09:52 AM
it's in the general maintenence sticky
but this is what you need:
http://forums.maxima.org/4872793-post12.html
http://pages.cthome.net/bbachinsky/nissan_ecm_codes.htm
Old Jul 5, 2008 | 08:32 PM
jromero1985's Avatar
im having this same issue
My 1990 nissan maxima surges when idling in drive and gets no power and makes a fluttering noise like an exhaust problem. What is the problem? if any one has any answers to this please email it to me at jromero0602@tmail.com i can figure out what it could be
Old Jul 5, 2008 | 08:39 PM
um.... no, you're NOT having the same issue. or are your powers of reading comprehension that shot? go post in the n00b thread.
Old Jul 6, 2008 | 06:05 PM
maxim90's Avatar
Well, I swapped relays (ENG CONT) and nothing. I am going to check codes tomorrow. I am at work right now and am driving my BMW. I will let you know which codes come up capedCadaver as soon as I get them.
ALso....With the key in th on position....I am getting a humming/buzzing sound from the top of the transmission just under the MAF sensor at the pan. When I turn the key off....The IACV is clicking 4-5 times. I got some wierd Sh#t going on here.
Old Jul 6, 2008 | 07:02 PM
the buzzing sound is the drop resistor for the a/t
Old Jul 7, 2008 | 12:35 AM
daftinnovations's Avatar
mine would cut off when i would turn to the right really hard. ended up being the ignition relay under hood was like vibrating apart i had to take out and tighten the bolt under the relay
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
