how to check 94 maxima ATF
Old Jul 14, 2008 | 03:18 PM
lalonaruto's Avatar
hi guys i just changed the transmission fluid on my 94 maxima gxe, and i dont know how to check if the amount of fluid i put in is right or not. the dip stick has a cold side and a hot side.
Old Jul 14, 2008 | 04:19 PM
cheatham's Avatar
I need a brake.
Originally Posted by cheatham
A reminder- check transmission fluid with car running and in park. After filling fluid run the transmission through the gears before checking. When it is in the grid, drive around the block so it can shift through the gears and get up to operating temperature then check again in park.
Use hot side to check after you have driven the car.
Old Jul 14, 2008 | 05:53 PM
DanNY's Avatar
Ad·min·is·tra·tor
drive the car to warm it up..NOT hot.
park on a level surface and keep the car running.
check the dipstick like you would on the engine. look at the hot side. if it's low top off slowly. it doesn't take much to reach the top.
lux97Max
19
Aug 27, 2015 07:48 PM
acw
Aug 13, 2015 12:50 AM
altmycar
Aug 6, 2015 04:44 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
