Turbo
Old Jul 16, 2008 | 06:17 AM
'93maximaGXE's Avatar
Turbo
Why do i always see 3rd Gen Maxima's with T4 and T5 turbo's? i want to rebuild and turbo my 93 GXE but was thinking why not go with a major HP gain and get a T88 or something. Also, where should i look for inexpensive parts to rebuild my engine?
Thanks.
Old Jul 16, 2008 | 06:22 AM
internetautomar's Avatar
mod or sell?
turbo + inexpensive = boom
Old Jul 16, 2008 | 07:26 AM
hahaha, well i meant, the least expensive parts.
Old Jul 16, 2008 | 07:46 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
take a look a few links down at MaxMaxima's new setup. his turbo is the size of your head. and he makes 400+ WHP.
Old Jul 16, 2008 | 07:51 AM
mtrai760's Avatar
'Trynna' is not a word
If your already thinking about cheap parts, then FORGET turbocharging your car. You cannot afford. it.
You gotta pay to play.
Old Jul 16, 2008 | 08:02 AM
alrighty then. where should i get the parts?
Old Jul 16, 2008 | 08:14 AM
well i don't think he was looking for cheap crap.... rather just the best price on good stuff. cuz you know a lot of places will charge you way more than the parts are worth. like the JY i don't go to anymore... wanted $75 for a used window regulator. or $550 for a 5spd tranny. so i went and bought a parts car for $200 less (and for being a parts car, it ran good enough that i'm taking the motor for my car too). so yea... i guess what he's looking for is best bang for the buck
Old Jul 16, 2008 | 08:17 AM
thats exactly what im looking for. thank you.
Old Jul 16, 2008 | 08:39 AM
kzoosho's Avatar
I got all my stuff from my favorite place, Ebay. I got the turbo for 450 (turbonetics 60-1) and the intercooler,piping, couplers, clamps, and downpipe flange were the ebay kit. I am using a n2o line for my oil feed with a restrictor from atp. It can be done fairly cheap but you dont want to cheap out on your tune. You can have a 10000 car and a bad tune and you will end up with a 10000 parts car.
Old Jul 16, 2008 | 09:23 AM
Jeff92se's Avatar
I'm needing a caw
Thanks.
T88? If you hit the gas on monday, you might built boost by tuesday
Old Jul 16, 2008 | 09:27 AM
and on wednesday you'll either be moving at mach 2, or be in the shop with a blown headgasket...
Old Jul 16, 2008 | 09:30 AM
3g94MaxGXE's Avatar
Hahaha I was wondering why nobody mentioned turbo lag. Either way unless you've got a fully built motor I don't see what a big turbo would do for you cause you will end up wit engine problems in no time.
Old Jul 16, 2008 | 09:41 AM
and then there's the issue of massive HP in a FWD car will just lift the front and spin tires. that's one time when a high-end biased engine is good tho... because once you're moving you can turn on the power, but just taking off through 1st and the shift into 2nd... it simply can't take that much power. maybe an a/t is a different story... but the VG AT won't take but about 5 miles of t88 abuse before throwing in the towel.
Old Jul 16, 2008 | 09:44 AM
3g94MaxGXE's Avatar
Yep I was with you there a long time ago or I would be rolling in a turbo Maxima by now. Funny thing is we're now talking about traction issues in 2 threads.
Old Jul 16, 2008 | 03:07 PM
sleepyvg30e's Avatar
when it comes too turbo bigger is not always better check out the vg30det somehow they added a smaller t25 to replace the t3 which somehow gave the engine the exact same hp but 5ftlbs more torque and has less turbo lag which is good unless your trying to break a land speed record
Old Jul 16, 2008 | 10:09 PM
3g94MaxGXE's Avatar
Well the reason the T25 can produce the same boost is the fact that factory turbos are not usually set up to run at their limits. So you get a 5-7lb boost factory turbo that just as easily could put out lets say 10-15lbs. You can replace it with a smaller turbo, run it closer to it's limits and make the same horsepower, get less lag but the bad part is the factory turbo would be capable of a bit more if you desired it.
Old Jul 17, 2008 | 01:53 PM
Darkwing48's Avatar
Please elaborate or point me towards a thread that you discussed this. It Sounds interesting
Old Jul 17, 2008 | 01:57 PM
no thread in particular. it's just a few concepts that can fairly easily be reasoned through when considering how a car will behave in different circumstances. like the fact that the faster you are going, the more tq you can put to the wheels without spinning them. or the fact that the car's nose lifts during acceleration and that's bad on FWD. a/t will smooth out the launching and shifting so you won't chirp as hard (b/c you have a tq converter), but the vg a/t has enough trouble as it is...
Old Jul 17, 2008 | 06:48 PM
has anyone ever built a twin turbo with one small turbo to reduce lag and one larger turbo for the high end that the VG lacks
Old Jul 17, 2008 | 08:13 PM
3g94MaxGXE's Avatar
I don't know about on the org but alot of manufacturers do it.
Old Jul 17, 2008 | 11:29 PM
that is probably most likely what i will be doing.
Old Jul 18, 2008 | 07:41 AM
Cinnamint's Avatar
Go with a small turbo and low boost on stock compression. It's cheap and no lag.
Old Jul 18, 2008 | 08:01 AM
mtrai760's Avatar
First you want the cheapest parts, then you want to do a twin turbo setup? Stop, your killing me!!!
Old Jul 18, 2008 | 08:16 AM
except that...
Old Jul 18, 2008 | 08:18 AM
mtrai760's Avatar
Right... People are always big talk until they realize that, even when finding good deals, building a 'simple' single turbo setup will run your around $2k-$3k IF you can do the work yourself. Let's not get into the elements of running a dual turbo setup in series.
Old Jul 18, 2008 | 08:20 AM
kzoosho's Avatar
Im going to run 6 turbos. One for each cylinder. That way i have instant boost and plenty of power. Im put them right where my seat goes so i can make sure they are working right.
Old Jul 18, 2008 | 08:23 AM
all T4s amirite?
yea.. i know what you mean there. and i know JUST enough about sequential TT to know that i'm never going to mess with it unless i have a spare car and $10k of "oops i f**ked up again!" surplus money.
Old Jul 18, 2008 | 08:26 AM
mtrai760's Avatar
You ever see the pictures of the guy that ran his turbo where his passenger seat used to be? I'm pretty sure it was on a 240, but I can't remember all the details now. I'm pretty sure the car caught on fire...
Old Jul 18, 2008 | 08:31 AM
ever seen this one? http://www.britishv8.org/Triumph/EdOlson/EdOlson-A.jpg
or this one? http://www.turbo-kits.com/images/sts...in_turbo_3.jpg
Old Jul 18, 2008 | 08:36 AM
mtrai760's Avatar
I don't see anything wrong with either of those
I was talking about a ghetto made, barely holding on turbo mounted where the passenger seat used to be, in a non-convertable car. Exhaust was leaking INSIDE the cabin! I've been trying to find pictures or the thread I saw on it for the last 10 minutes, no luck so far...
Old Jul 18, 2008 | 08:41 AM
whattingh's Avatar
I think this is what you think of http://forums.nicoclub.com/zerothread/200437
Old Jul 18, 2008 | 08:44 AM
nothing wrong with them... they're just also kinda bizarre, like the in-the-cabin one.
Old Jul 18, 2008 | 08:48 AM
a) EVERYONE can look in your window and see your car is TT.... theft risk much?
b) VG AUTO Twinturbo?
c) must be hot in there
d) so... he ruined his cabin to keep the turbos out of the engine bay... but STILL had to relocate his battery. smooth.
e) i thought the intercooler went post-turbo... his is preturbo
f) if the turbo blew up, i'd rather have it under the hood where i WON'T get shrapnel in my eye, arm, etc... and not be deafened by the exhaust blasting in my with no muffling, etc etc.
mtrai760's Avatar
FOUND IT!!! Best part is, It's on a turd gen!!!
Complete thread is here with more pictures: http://www.thewolfweb.com/message_to...=413656&page=2
Old Jul 18, 2008 | 08:49 AM
mtrai760's Avatar
Yeah, same thing.
Old Jul 18, 2008 | 08:56 AM
kzoosho's Avatar
Damn someone had my idea. BUt im do it with 6 not 2. Go big or go home. Then ima supercharge it.
Old Jul 18, 2008 | 11:19 AM
i like this one the best isn't just as possible to stick all that piping in the trunk instead of passenger seat that would eliminate most of those problems with..... ya know death when it blows up... but the trunk is fine just as safe as the engine bay with more than enough room plus you could really make them visible this way
Old Jul 18, 2008 | 11:58 AM
BenStoked's Avatar
Jesus was a Zombie.
[IMG]http://www.turbo-kits.com/images/sts_mustang_gt_twin_turbo_3.jpg[IMG]
part of the problem with a setup like that is air compresses, and will be lower psi by the time it gets to the engine (layman, as I understand it) because of all the piping from the back to the front. and likewise, for the exhaust, psi would be lower in the back, making it harder to push the turbos.
not to contradict myself, here, but some people have seen pretty decent results from it. I don't know of anyone in the 3rd gen forum, but I think there are in the 4th gen and 5th gen. may also want to check the turbo/supercharge forum.
Old Jul 18, 2008 | 04:38 PM
Deth's Avatar
Is there anyway a T4 or T5 would work with the new HKS special edition universal BOV with my VG30E?
Old Jul 18, 2008 | 08:52 PM
3g94MaxGXE's Avatar
That in car turbo setup is just nasty, who would do that and why?
