Axle question
What is the function of these grooves, and why would they be different?
http://www.mikekantor.com/forums/SNC11852.jpg |
I believe they are oil flow grooves..
Lemme guess..Your new axles different grooves (on the left ) made you think wtf? :scratch: Right? ;) |
correct
I think the one on the left is for LSD cars. Are those axles for the same side
Originally Posted by GAMERA30
(Post 6656943)
why they r so different...the one on the left in ur pic is the one in my VE and doesn't go all the way in. i can see the half groove out from the bottom of my car and my tranny oil leaks jus cuz of then....does it fit in urs?
and ya those r oil flow grooves...and they r pretty different....i didnt know that after market axles r different than OEMs:scratch: |
Originally Posted by burhan92SE
(Post 6656961)
(Post 6656979)
i'm still thinking you got shafted with your non-vlsd re4f04a..... oh well. but i'm guessing those are just 2 different styles. cuz i had a bad set of VE axles and a good set... and one had the type on the left and one had the type on the right... so i dunno why they're different in that respect but the function is basically the same.
(Post 6656987)
so u think some VE AUTOs came with non-vlsd too...? cuz i know the tranny in my VE isnt VLSD cuz it has that shinny PIN in there...and VLSD doesnt have that.....
The axle fits just fine, and is identical in every other respect. I got it from Brian and its been in for a few weeks, no leaks or other problems, I was just curious about it. |
Originally Posted by mikekantor
(Post 6657039)
Yes, there are VLSD and non-VLSD VE autos. You can check by looking at the metal plate on the firewall because it has the transmission name, and it will have a V in it for VLSD. Dealerships can look it up using the VIN, although the actual VIN doesnt have enough detail for it, their database does.
(Post 6657039)
(Post 6657050)
There were non LSD VE auto ???... wow ... I thought ALL VE reguardless of auto or manual was VLSD....ARE YOU SURE ???... cus VG and VE axles are not interchangeable in Auto trim. I know VG cars are not VLSD.
(Post 6657052)
ya i have V for transmission code on the firewall but the tranny i have is not VLSD, jus cuz of that axle doesnt go all the way in......and i have VE engine...i think someone before me messed something up ( wrong tranny ) or SOME VE AUTOs just came with none LSD tranny.....i still drive the car with that axle but it jus doesnt go all the way in lol...
The non-VLSD VE auto should look different externally, and VE autos are fairly bulletproof so I would be surprised if yours was swapped. |
(Post 6657052)
Originally Posted by pmohr
(Post 6657113)
If your VIN plate says RE4F04V and you're sure that your current trans has an open diff, then that means someone swapped it out at some point. Do you think it's open because the axle won't go all the way in?
(Post 6656943)
(Post 6656950)
both axles pictured are the inner joint of the driverside axle on the VE LSD tranny. note 2 sets of splines? 1 for the diff casing, 1 for the VLSD unit.
now that's definitely a different axle.
in the USA ALL VEs left the factory with a VLSD.
when the trans has been replaced, what people put back in is another story entirely. |
thats what i thought... the FSM dont state anything else.
(Post 6657113)
(Post 6657091)
Yeah they exist, I dont think they are very common. If you go to a parts website they will have an axle listed for every permutation of options: Passenger/Driver, ABS y/n, VLSD y/n, VG/VE, MT/AT.
Are you sure its pushed in all the way? The ring has to snap in place. I think some of the axles have different tooth counts, so it shouldnt be so easy to make the wrong one fit. Axles are not a lol-ing matter, get it figured out. The non-VLSD VE auto should look different externally, and VE autos are fairly bulletproof so I would be surprised if yours was swapped. I've seen pics of his splines and inside his diff holes.... there is a big pin in the middle, rather than a clear hole all the way through. According to the FSM and other things I've seen, all the ones with pins through them (VG auto and VG manual) are open diff, and the VLSD has no pin in the middle due to a different bezelgear carrier design. So his tranny is definitely open-diff. |
ok here it is....i have VLSD axle and this is wat it is and this is how far it goes in thats it...no more room.....i can still drive the car....i think i have to try VG inner board.....
edit: and wat i think is that the second spline of the VLSD axle doing the job of the grooves....:scratch: |
(Post 6658240)
(Post 6658267)
i wonder if a 4th gen axle would fit your VE hubs and fit your 4th gen tranny (it basically is that, just with a VE tc housing)
(Post 6658275)
ya cuz i bought a VG axle before and wasnt fitting my wheel side...it was too small.....so should i try 95 maxima driver side axle NONE-LSD...?
wth...they have axle for 1992 maxima SE WITH ABS AND WITHOUT LSD? ( the first one )
http://cpwstore.carpartswholesale.co...7+9274+814+145 |
(Post 6658299)
(Post 6658305)
well try that then. i know some other countries had non-vlsd VEs.... so maybe that's just sourced from there.
Originally Posted by ColombianMax
(Post 6658336)
I thought the VE was only available in the USA and probably Canada... I demand for everyone reading this post and has a VE auto, to go check their trans code and let us know if anyones code ends with an "A":cool:
(Post 6658347)
my code ends with ''V'' but i have got the wrong tranny...but could be possible that in some other countries VE autos came with NON-VLSD TOO... since NISSAN never mentioned about BROUGHAM edition so it is possibile they never mentioned about VE autos NON - LSD either...:scratch:
(Post 6658336)
Repeat:
All USDM VEs had VLSD installed from the factory. the companies got it in their heads some time ago that a non-VLSD VE exists, but it NEVER came from the factory that way. |
I want my hood struts brian!
(Post 6659317)
(Post 6659065)
Repeat:
(Post 6659931)
some auto VEs could have came NON-VLSD in CANADA? i m going to dealer tomorrow to make sure this confusion....dealer might be able to tell me wats the truth right?...
(Post 6659936)
i'd think it'd be in a poorer country... like Brazil. I know they had 3rd gens in brazil cuz there are a few different wires in the Brazilian version. don't need VLSD in the jungle as much as you need it in the snow
lol.....just wondering and as far i can think Canadian 3rd gens came in various versions than U.S |
(Post 6659946)
what if my 3rg is from BRAZIL:surprised.........
u got a point there...
Funny how this tread went from an axle question to a transmission info site on VE trannys...lol
(Post 6660046)
© 2024 MH Sub I, LLC dba Internet Brands
