****_____Lights Issue_____****
Old Dec 8, 2008 | 09:00 AM
raeqwon28's Avatar
I have a issue with my lights on my dashboard,rear tail lamps and front side markers not coming on when turning the secondary switch on the light swith.
First, I search the forumn and investigated all the options. Second, I check the schematics and the only thing I came up with is the fuse box and the light switch.
I check the fuse and nothing changed. Switch out the light switch with another one(a used one) and nothing happened.
Can anyone tell me what the probelm might be? Any help,lead or suggestion will be appreciated.
P.s. The turn signals,Hazard and stop tail lamps work.
Old Dec 8, 2008 | 09:07 AM
Pearl93VE's Avatar
I can has?
In the fuse box, replace your Stop Lamp fuse.
Old Dec 8, 2008 | 10:06 AM
Wiking's Avatar
Originally Posted by raeqwon28
... or suggestion will be appreciated. ...
Open & check rear lamp assembly's for short circuit.
Old Dec 8, 2008 | 01:07 PM
Greeny's Avatar
¯\(°_o)/¯
and corroded bulb sockets..
Old Dec 8, 2008 | 03:11 PM
raeqwon28's Avatar
Thanks all . I got it working
Old Dec 8, 2008 | 03:21 PM
Greeny's Avatar
¯\(°_o)/¯
What was the problem?
just so anyone searching for the same problem knows what actually fixed it.
Old Dec 8, 2008 | 03:48 PM
raeqwon28's Avatar
It was the Tail Lamp Fuse. I overlooked it.
Old Dec 8, 2008 | 07:08 PM
internetautomar's Avatar
mod or sell?
which brings me to one of my rules, check every fuse every time
Old Dec 8, 2008 | 11:25 PM
Wiking's Avatar
True, one cant trust the Nissan con-fuze tables.
Volvo has another rule on top (with the older type fuses): add contact grease in all.
Old Dec 9, 2008 | 07:06 PM
mod or sell?
actually mine comes from the fact that some fuses control things that don't make sense or aren't clearly listed.
my current 94 SE sport has a common issue in that the rear wiper motor is blown. that trips the airbag light, I had to unplug the rear wiper motor and replace the fuse for the airbag light to go off.
