trunk light
Old Jan 16, 2009 | 02:33 PM
Midnight Racer's Avatar
trunk light
Mine doesn't work and I need help, I have searched and have tried moving the little switch on the latch but I get nothing not even a flicker, does anybody know anything else I can do
Old Jan 16, 2009 | 02:41 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
just gonna throw this out here..... did you replace the bulb yet?
Hectic's Avatar
It's probably burnt out dude. Unless of course the bundle of wires was chopped like mine was when I got it.
Old Jan 16, 2009 | 02:50 PM
get some 12" white Cold Cathode tubes and wire them up instead. it'll be a LOT brighter. assuming the bulb is just burned out.
Old Jan 16, 2009 | 03:00 PM
I replaced the bulb yesterday so its not the bulb
Old Jan 16, 2009 | 09:06 PM
burhan92SE's Avatar
why dont u check the voltage in harness under the rear speakers cover pull that out and u will see harness dere and check it out....and is ur front D-Side door sensor working?
Old Jan 17, 2009 | 08:58 PM
gapboi210's Avatar
mine has not worked since I bought the car. Checked the bulb. Guess I need to get a wiring diagram and a test light.
Old Jan 25, 2009 | 11:26 AM
Infam0usMax's Avatar
I thought i was the only one with this same problem I have replaced the bulb twice and still get nothing from that damn thing i have to use a flash light in the night to look around in my truck and under the hood i dont even see a spot where the light should be whats up with that?
Old Jan 25, 2009 | 11:35 AM
chrome91's Avatar
theres a trunk light? i never even knew, mine probably doesnt work either
Old Jan 25, 2009 | 12:13 PM
stevex's Avatar
check this cable. I've got same problem and fix it.
Old Jan 25, 2009 | 12:21 PM
chrome91's Avatar
hmm, dont know if i'll fix mine. i only use my trunk for the subwoofers and im rarely digging in it
Old Jan 25, 2009 | 06:49 PM
ok kool will do and ill let u know if that works
Old Jan 25, 2009 | 07:56 PM
klemenz's Avatar
I thought it was too dim anyways.. I replaced mine with an led light bar.
Old Jan 27, 2009 | 08:07 PM
Thats why I want to figure out why mine doesn't work, I too want to install an led bar to show off my subs but want it to come on only when the trunk is opened
Old Jan 27, 2009 | 08:23 PM
teamshultz's Avatar
Think a fluorescent light tube will hold up in there? I have a spare one layin' around from the reptile days that I might wire up.
Old Jan 27, 2009 | 11:10 PM
I just wired up my trunk today with a neon bar its a little LED though but to wire it from the sub use the amp wire that runs to that batter/the power cable then for it to only cut on with when the trunk is opened pull back that cover or just cut the wire that runs to the trunk light and my wire was pink u might see like 4 wires but its either ur pink wire if urs is pink also or the black wire that runs to that trunk latch ill take pix 2marrow to show u what im talking about and mine works just fine only thing is that damn light is not bright enough i dont know why tho maybe because it was a $9 light lol and its little so yeah word of advice if ur gonna get a tube it a good one that u know will put out a good bit of light...
Old Jan 27, 2009 | 11:12 PM
i did wire up my little led bar today well yesterday and its way too dem so do u have a pic of yours and where/how did u wire yours?
Old Jan 27, 2009 | 11:52 PM
go for it. i'm either gonna use a trio of 8W fluorsecent tubes, or some 12" cold cathode tubes. i plan to just put a relay on the wires for the stock trunk light, and let the switch portion just draw a line off the battery, cuz i'm not sure how much current is safe to pull through the stock wiring for the bulb.
Old Feb 2, 2009 | 02:57 PM
big thanks just did this today and works perfectly, now I can finally order my led tube
Old Feb 2, 2009 | 04:19 PM
Sorry i didnt get around to posting the pix but ur welcome...
Old Feb 7, 2009 | 11:20 PM
The new replacement tubes... blue Cold Cathode Light Kit, 12"s and yeah they are way brighter then that led crap that i have in my trunk now so yeah thankx for the heads up guys im thinking about buying a few more... how would i wire these up with a off and on switch tho?
Old Feb 8, 2009 | 02:36 AM
internetautomar's Avatar
mod or sell?
wire it into the existing trunk light.
Old Feb 8, 2009 | 05:16 AM
burhan92SE's Avatar
i replaced my factory bulb to this more amp drawing bulb. MUCH BETTER light output than stock bulb...only $1.50 from wallmart and been using since 1 year now....
Old Feb 8, 2009 | 08:53 AM
what is the wattage on that? the stock one is what, 8W? something like 20W would be adequate.. but you'll still get the most lumens per watt with either fluorescent or cold cathode.
Old Feb 8, 2009 | 10:45 AM
The LED that i have in there now is wired to the trunk light but what if i wanted to put in somewhere inside the car i.e. under the dash? where would i run the wires from?
Old Feb 8, 2009 | 11:47 AM
HTPerformance's Avatar
Back in the day I installed a spare fog-light with an on/off switch in the trunk, which provided superb lighting back there. I wish I could find the pictures.
Old Feb 8, 2009 | 06:03 PM
burhan92SE's Avatar
factory trunk bulb is rated at 3.4W at 12 volts = 0.28 Amps
and i replaced it with 12W bulb at 12 volts = 1 Amp
and it wouldnt hurt to pull a lil more amps through stock trunk lamp wiring...
Old Feb 8, 2009 | 07:39 PM
BenStoked's Avatar
Jesus was a Zombie.
I actually tested my new ccft current, it is 1a.
Old Feb 8, 2009 | 11:11 PM
how's the output on it? yay? nay? meh?
Old Feb 8, 2009 | 11:45 PM
when i hook them up to my CPU they are 100x brighter then that LED i have
Old Feb 9, 2009 | 03:38 AM
pmohr's Avatar
No more Maximas...
I did the same thing a few years back, a pair of cold cathodes. It's actually a lot brighter than the pic shows.
Now that I look at that picture...I wonder why the hell I had a lightbulb in my trunk.
Old Feb 9, 2009 | 12:01 PM
does anybody know how to set up these light with an on off switch...? like if i wanted to put it under my dash in the from of the car what would i have to connect it to?
Old Feb 9, 2009 | 12:42 PM
BenStoked's Avatar
Jesus was a Zombie.
find a 12v source (radio is a good start, you have a choice of constant power, and power when ign is in acc or on). find a place to mount the switch. mount bulbs and inverter w/ double sided tape (included). hook up connectors, test, enjoy pissing yourself off at night because you cant find/reacht the switch, and are blinfed by the bright *** lights under your dash.
(note: colored wire that goes to computer power is positive, black is negative)
Old Feb 9, 2009 | 12:58 PM
coolsun's Avatar
These Cold Cathode wont be needing any resistors right? cause the Input voltage of the inverter is 12v right?
Old Feb 9, 2009 | 01:00 PM
pmohr's Avatar
No more Maximas...
Correct, they run off of +12VDC from a computer power supply.
Old Feb 9, 2009 | 01:52 PM
thankx for the advice but i really didnt need the scarcasim... i was just thinking about doing it why would i ride down the road with them on..thats kind of the whole point about the on off thing... but yeah like i said thanks for the info
Old Feb 9, 2009 | 01:57 PM
if you wire it into the socket for the original bulb then that won't be an issue anyways
Old Feb 9, 2009 | 01:59 PM
ok..
Old Feb 25, 2009 | 11:32 AM
The cold cathode tubes that i have are not lighting up anymore but i did unhook the wires and just tried to run the wires str8 to the tube itself without the little black box that came with the set is that box suppose to be hooked up to control the amount of power going to the light?
Old Feb 25, 2009 | 11:47 AM
pmohr's Avatar
No more Maximas...
That's not so much a power regulator as an inverter. You can't run straight DC power to the tube. Why the hell would you remove the inverter? What did you think it was, an 'extra part'?
