So where does this plug go?
I've had my interior ripped apart for about a month now after fixing/welding up my broken clutch pedal mount. I was too lazy to put it all back together back in December and I've been driving it to/from work with just the gauge cluster in. I have all the wiring stuff hooked up but I can't figure out where this plug goes. The plug is hanging down around under the steering column. My blinkers don't work (even after plugging in the hazard switch) and I'm hoping this has something to do with it.
So, please, somebody identify it for me
I think you can click the pics for full size ones
Oh, and take that stupid clutch pedal mount!
I'm going to bet that plugs into the back of the fuse/relay/blinker panel on the left side of the dash. those are some fairly good size connectors, which means they pull a decent amont of current. those are also the size of the connectors typical on a relay.
so my guess is that it plugs into the back of a relay or something. look on the left side with all of the fuse panel stuff.
Well good Lord, you're right Matt.
After swearing off laying on my back in that dumb floorboard I just did it again and after tediously checking every connection my eyes magically happened upon a little black relay box hidden behind the door lock timer.
And what do you know, it plugged right in and was the relay for the blinkers
Thanks, and stuff, traitor!
TKHanson
Nov 24, 2018 01:39 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
