odometer got stuck!!! help
hey guys, need your help again. My odometer got stuck while i was driving. It doesnt make the numbers go up on the miles, same with the trip thing. What can i do to fix it, have a 90 SE 5spd. Also when does the light for fuel should ligh up?? Thanks!
Re: odometer got stuck!!! help
ohh yeah my speedo works, what was i trying to explain is that the one that shows how many thousand miles u have, and the one next to it the one that show in hundred miles. those are the ones that dont work
how much is the sensor?? can i get it from a 1992 max SE 5spd?? cause i have a wrecked one at friends house. willit fit my 90 max SE 5spd?? thanks
If your speedo works but your odometer doesn't I would rule out your speed sensor. It is most likely the solder connections around the micro that drives the odometer. You could try resoldering the connections or get a replacement cluster or individual unit that houses the odometer.
Brent
Brent
Brent
Brent
tarun900
19
Dec 20, 2021 06:57 PM
mkaresh
Mar 12, 2018 06:48 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
