1994 VG Check Engine Light On
Old Mar 16, 2009 | 09:32 AM
fattamax's Avatar
My check engine light came on the other day and car has hard time staying running. My car normally doesnt like the winter but it is not real cold here in GA (55deg.) so I dont know why it is running this way or how to find out what the problem is without taking it in the but at the Nissan dealership. Can anyone help?
Old Mar 16, 2009 | 11:50 AM
Greeny's Avatar
¯\(°_o)/¯
You can retrieve the trouble codes yourself on these cars..
How to access the codes--> http://forums.maxima.org/3rd-generat...-then-off.html
Code chart---> http://pages.cthome.net/bbachinsky/nissan_ecm_codes.htm
Check the codes, report back to this thread with the results..
Old Mar 16, 2009 | 01:27 PM
fattamax's Avatar
Thanks man I am gonna check the codes tomorrow...raining out of control here in GA and I've so much crap in my garage that I cant get the car in! Thanks for your help!!
Old Mar 16, 2009 | 02:13 PM
Greeny's Avatar
¯\(°_o)/¯
I hear ya man, we have had so much rain here the past few days, i'm about ready to trade the maxima for a rowboat..
Old Mar 16, 2009 | 02:18 PM
burhan92SE's Avatar
its so windy here like krazy.....my car shakes...
Old Mar 16, 2009 | 05:00 PM
FloppyJunk's Avatar
I am getting this code too...
At least I think so (Code 13) Cylinder Head Temperature Sensor. Is this the sensor near the Fuel Pressure Regulator. I know some vehicles have more than one.
Thanks,
Aaron Harkness
Old Mar 16, 2009 | 05:32 PM
burhan92SE's Avatar
Thanks,
Aaron Harkness
its coolant temperature sensor....and ya its near the FPR....RED one...not the blak small one thats temperature sending unit to ur temp needle on ur dash....change that CPS its easy to change....
Old Mar 16, 2009 | 05:45 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks,
Aaron Harkness
See the little sensor to the left of the coolant temp sensor (red plug) that is the CTHS.
Old Mar 16, 2009 | 05:46 PM
Greeny's Avatar
¯\(°_o)/¯
No, it's the CTHS...
Old Mar 16, 2009 | 06:03 PM
FloppyJunk's Avatar
Ahh.. Hmm..
Well, I puled the connector and tried to squeeze the prongs a little closer together, cleared the codes and it came back. So, I am going to have to check tomorrow and see if there is a short in the wiring harness and if not I guess I will have to change it.
Could this be causing an intermittant knocking noise I hear around the firewall?
Thanks,
Aaron
Old Mar 16, 2009 | 06:11 PM
Greeny's Avatar
¯\(°_o)/¯
Just replace the sensor dude, the harness being faulty is a long shot at best..
Old Mar 16, 2009 | 06:23 PM
FloppyJunk's Avatar
Maybe I should elaborate. I just tore down the top so that I could replace the K/S. that is why I am thinking maybe cracked a wire. They were pretty brittle. Maybe not, if I can find one locally easily I will just replace it.
Old Mar 16, 2009 | 06:33 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah, you really should elaborate on work done in your original post...check the wiring...
Old Mar 16, 2009 | 06:36 PM
FloppyJunk's Avatar
Cool, thanks big guy.
Old Mar 16, 2009 | 07:45 PM
internetautomar's Avatar
mod or sell?
CHTS
Old Mar 16, 2009 | 07:47 PM
Greeny's Avatar
¯\(°_o)/¯
CHTS
i was thinking about you when i made that post..
Old Mar 16, 2009 | 07:48 PM
mod or sell?
you did it twice
Old Mar 16, 2009 | 07:49 PM
Greeny's Avatar
¯\(°_o)/¯
you did it twice
Cuz i need a TBI spacer..
Old Mar 16, 2009 | 07:52 PM
mod or sell?
no got one of those.
one of these days I'll look for the cam
Old Mar 16, 2009 | 10:51 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
no it isn't it's the CTS (red sensor, for the OP's info)
the FSM says that a code 13 (on either VG or VE) is the "Engine coolant temperature sensor". look at EF&EC-259. just going on a limb here, but FSM > some random website
the ECU never sees the signal from the CTHS. the circuit for that goes from the fuseblock, to the cluster, to the sensor, and grounds on the body of the sensor.
ibbannedforaweek
Old Mar 17, 2009 | 04:32 AM
Greeny's Avatar
¯\(°_o)/¯
ibbannedforaweek
Heh, i can't look at the fsm atm..(remember: dropped lappy)= pc freezes when i try to view any pdf..
Old Mar 17, 2009 | 01:06 PM
it's ok i forgive you
Old Mar 17, 2009 | 09:39 PM
burhan92SE's Avatar
probably u dont have much page file left for PDF to use
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
