Electric windows stopped working
Old Nov 18, 2001 | 11:41 PM
JoeWillie
Hello to All,
My electric windows stopped working on my 1990 maxima. I checked the fuse box on the driver's side, but did not see a fuse for the windows. All input welcomed.
Thanks,
JoeWillie
Old Nov 18, 2001 | 11:58 PM
Neice Anne
Re: Electric windows stopped working
Originally posted by JoeWillie
Hello to All,
Thanks,
JoeWillie
My left rear did too, I think it's the motor, because I can hear it trying, but it won't move
Old Nov 19, 2001 | 06:24 AM
«§»Craig B«§»'s Avatar
if you can hear the motor, but the window doesn't move, 99% chance it's the regulator (search for regulator and you will find tons of info)
check my how-to page for info on how to replace it easily http://www.prism.gatech.edu/~gte671n/mymax.html
Old Nov 19, 2001 | 09:01 AM
JoeWillie
What direction should I go in if I can't here the motors? I get no sound at all.
JoeWillie
Old Nov 20, 2001 | 09:08 AM
JoeWillie
Found the problem
It turns out that the dirver side window control module is bad. I took it out and sprayed the switches with contact cleaner. Now the windows work, but the door lock, window lock, and quick down switches stopped. I'll just replace the whole thing with a used module. I found one for $75.00.
Thanks for all the input.
JoeWillie
Old Nov 21, 2001 | 08:35 PM
AKAICEBERG's Avatar
The same thing is happening to me. My drivers side window switches are messed up. The 2 rear and passenger windows will roll down but not up. I have to go around to each individual window switch to roll them up that way. I tried spraying CRC QD electronic spray and it didn't cure anything. I should be getting some new switches soon.
Laters
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
shaunkey1
Aug 18, 2015 10:09 PM
kenc15
Aug 5, 2015 08:29 AM
