Passing Smog
Old Apr 1, 2009 | 11:32 AM
plaman88's Avatar
Passing Smog
I searched and I can't get my VG30 to pass smog! First time I had 134 vs the needed 120 on my HC levels. Next I tried to get the car warmed up really well and got 131 vs 120 but I still need less! Everything else passes fine and I'm fresh off a tune-up and oil change. What am I missing!?
Old Apr 1, 2009 | 11:40 AM
1993-VG30E-GXE's Avatar
Seafoam
Old Apr 1, 2009 | 12:13 PM
plaman88's Avatar
Does that fix HC levels or are you just padding your post count?
Old Apr 1, 2009 | 12:39 PM
All I know is mine failed once, then I did the seafoam into my gas tank, and then I re-tested and I passed. I'm not 100% certain though it was retested on the exact same machine though.
Old Apr 1, 2009 | 01:17 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
check your ECU's codes to see if anything is causing a 'phantom' check-engine light. the lights on our cars basically never light up when there's a problem, but it'll still store codes. I don't know what causes high HC levels but maybe your o2 sensor or coolant temp sensor or something could be bad (or bad wiring like i had), causing it to run rich, etc.
Old Apr 1, 2009 | 01:55 PM
LvR's Avatar
LvR
High HC implies unburnt fuel
Caused by:
Timing
Ignition system - plugs/leads/cap/rotor
Fuel metering system - ECT/O2/MAF/EGR/FPR/Injectors/ECU.
Engine condition - blowby/intake and TB gunk due to PCV
Basic maintenance/tuneup required
Old Apr 1, 2009 | 04:43 PM
internetautomar's Avatar
mod or sell?
a bottle of rubbing alcohol (70% alcohol by volume) in the tank does wonders for high HC
Old Apr 3, 2009 | 10:07 PM
OnTheRoad's Avatar
How do you access the codes? I got the thing to flash the 5 green and red LED sequence, but could get it to do much more. EF & EC40 of the service manual. I could find a plug location for an external scanner.
Mar 12, 2020 12:06 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Jay556
Sep 12, 2015 05:50 PM
