1992 max se SAFETY RELAY
There should be. It's a relay that cuts off power to the fuel pump in an accident. Should be in the trunk area. You might have to dig under the carpet or around the center tailight areas.
Advice. don't use all caps. It's quite irritating.
there are 2 relays in the trunk - safety relay and fuel pump relay
you will have to take off the trunk liner that goes on the backside of the taillights and all the way across to the other taillight
first remove the screws holding the plastic piece on that goes across the bottom lip, then pop out all the trim fasteners (little buttons looking things) and pull the liner out
you will see the relays on the drivers side just inside the taillight assembly
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
