crack wire insulation repair
Old Apr 16, 2009 | 11:24 PM
OnTheRoad's Avatar
My 93 Maxima GXE has lots of cracks in the fuel injector wires and other wires (all 12V). Is there any easy to apply product to seal the cracks? A brush on product would be easier to use than electrical tape and be heat resistance.
OnTheRoad
Old Apr 17, 2009 | 02:11 AM
LvR's Avatar
LvR
Quick and honest answer? - no - don't waste your time.
The insulation is cracking because of heat+UV affecting the plastic causing it to go brittle - you apply a fix here today and tomorrow you have a new fresh crack half an inch away - the only proper cure if its bothering you is to replace the wire.
Apart from that - those cracks allow water/chemicals to seep into and in between the copper conductors inside the cracked insulation ................. often going for the length of the wire, so you effectively end up making a pile of poo look fresh - thats all.
Old Apr 17, 2009 | 03:31 PM
internetautomar's Avatar
mod or sell?
OnTheRoad
Old Apr 19, 2009 | 07:19 PM
James92SE's Avatar
2 VE's are better than one!
This stuff actually works pretty well, surprisingly! I used it in a couple spots on my Civic when I ran out of heat shrink and was too lazy to go buy more. Dries pretty quick too
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
