3rd gen turbo build
Old Apr 30, 2009 | 06:59 AM
blown-n-boosted's Avatar
3rd gen turbo build
Finally after 15 posts I can start me a thread. This is a rapid build that I'm doing right now and putting all my time in it. Once completed its going up for sale so pm me if interested.
1st I started with a 90 se 5 spd that was totally fubar.
Old Apr 30, 2009 | 07:00 AM
I then bought a 94 gxe for $300 and drove it 4 hours home with a supposed slipping trans but I had no problems but a slight miss under light accel.
Due to the non stop spring time rain work has been slow and wet. !st thing I did was go ahead and swap the interior from the tan color to black.
every thing tan was taken out. All the way down to the seat belts. I re wrapped the head liner and upper trim pieces in black vinyl and I then went ahead and swapped out the tails and spoiler.
Old Apr 30, 2009 | 07:02 AM
I've already ruffed in the intercooler.
As soon as he rain stops I've got to replace the lower core support and prep/paint the engine bay flat black. Ive already started the wire tuck and some parts deleted(ac,egr,cruise,ac,ect).
Old Apr 30, 2009 | 07:04 AM
windshield washer res and overflow might goe in the trunk with the battery since they're in the way of intercooler piping.
Due to the rain I've been stuck in the garage so I got the motor just about complete
5spd
Grand national turbo
Mod list so far.
W series block and heads
nistune
z32 tt injectors
walboro 255
aero fpr
custom y pipe 2 1/2" off each bank flowing into 3" to turbo
3" down pipe
3" straight exhaust out back no mufllers or cat
Garrett t3/t04 .63 turbine with t04b compressor internally gated
31" x 11" x 3" intercooler 3" in and out
dxd south bend stage 3 clutch
I'm starting to think that I'm going to make to much power for the 5 spd. Right now I should make a little over 300 horses. I could easily upgrade my injectors to some 555's or 880's and make some serious power but it would be an over kill. I can picture the trans right now.
more to come!
Old Apr 30, 2009 | 07:18 AM
Niccos89's Avatar
Looking sweet dude, keep it updated.
Old Apr 30, 2009 | 07:45 AM
GRNMAXDMON's Avatar
My goodness man, this looks like its going to be an insane build with those numbers that your going for. keep going and keep us updated.
Old Apr 30, 2009 | 08:13 AM
DanNY's Avatar
Ad·min·is·tra·tor
start looking for another body to put the engine in.
even the GXE is starting to get rusting from the rear.
Old Apr 30, 2009 | 08:16 AM
flyineagle96's Avatar
looking good
Old Apr 30, 2009 | 08:47 AM
maximaman1313's Avatar
I agree, or fix the rust issues now. they definately arent as bad as the first one.
Old Apr 30, 2009 | 09:04 AM
Garf's Avatar
lol @ the exploding strut in the SE. really nice to see someone with what looks like quite a bit of experience w/ VGET's and you're definitely moving along at a quick pace. wanna keep track of the $$ you put into the car just to see how much "bang" you get for your buck?
Old Apr 30, 2009 | 09:14 AM
kzoosho's Avatar
SO you are the one that bought Bens car. i was trying to get that car and use my 91 as the donor body. Good luck with the build . If you need any help man im only 2 hours way.
Old Apr 30, 2009 | 10:16 AM
Anything not structural or really bad with rust will just get a por 15 treatment before paint. Yea, this was all started from Ben. His brother bought the AE Z off of me and he asked if I was interested in the maxima 6 months ago. I didn't have anything going on a couple weeks ago so I just bought it to get me by. On the way home I knew that it was going to be more work than I wanted. Everything onthe car was crap. I ended up not useing alot of bens car because everything was just wore out. The turbo, injectors, fpr, 5spd , tails, spoiler,and interior is all I used. A lot less than originally planned. I've got to build a new y-pipe because Bens was very poorly made with poor welds. He also was running 2 1/2" exhaust but its to small for a boosted vg thats internally gated. I have an hx35w but the G/N turbo is enough so I'm going to save it for something else. Right now Its still raining so progress is really slow.
Old Apr 30, 2009 | 11:04 AM
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by blown-n-boosted
Anything not structural or really bad with rust will just get a por 15 treatment before paint. Yea, this was all started from Ben. His brother bought the AE Z off of me and he asked if I was interested in the maxima 6 months ago. I didn't have anything going on a couple weeks ago so I just bought it to get me by. On the way home I knew that it was going to beI ended up not useing alot of bens car because everything was just wore out. The turbo, injectors, fpr, 5spd , tails, spoiler,and interior is all I used. A lot less than originally planned. I've got to build a new y-pipe because Bens was very poorly made with poor welds. He also was running 2 1/2" exhaust but its to small for a boosted vg thats internally gated. I have an hx35w but the G/N turbo is enough so I'm going to save it for something else. Right now Its still raining so progress is really slow.
por15 is great stuff but not sure if you're able to get it in every nook and cranny around the quarter. something to consider.
Old Apr 30, 2009 | 12:23 PM
akurtzer57's Avatar
Not to burst your bubble but with that turbo going to be hard to make over 300hp. My 89 max using a to4e running 8psi probably only around 250hp. I went to 550cc on my 91 but im also running a holset he351 and 18psi. Not dynoed yet but sure its around 400 and tranny is holding so far.
Old Apr 30, 2009 | 01:44 PM
James92SE's Avatar
2 VE's are better than one!
Ding ding ding. Not to knock the OP, but that setup is not going to push 300 hp. Steal a neat project, though.
And dang that rust is outrageous.
I thought my car was bad, it's got rust in front of the rear wheel wells (well, on just one side since I repaired the other), but there's no sign of rust anywhere inside the cabin.
Old Apr 30, 2009 | 02:59 PM
I'm sure this turbo is good for 15 #'s at least if not I have a couple Z turbos laying around that I know will get an efficent 15. I have a fresh holset I could also drop on there but I'm planning on selling the car as soon as its done and planned on useing it on my turbo Z. Really the only thing holding me back would be my injectors/turbo.The next owner will just have to upgrade the injectorsthrow on a holset and dload a new tune. Simple.....Well for some anyways.
Old Apr 30, 2009 | 03:42 PM
ColombianMax's Avatar
wow, I was considering buyin that turbo 3g...I know it was rusty!
I've dropped by kzooshos a few times too and I believe you're in the way.. if anything let me too
Old Apr 30, 2009 | 07:50 PM
BenStoked's Avatar
Jesus was a Zombie.
how on earth are you going to move the radiator overflow into the trunk?
that needs to be pretty close to the radiator to get it to do its job right.
Old Apr 30, 2009 | 08:38 PM
buddy thats an easy one..just simply take radiator along with it
Old Apr 30, 2009 | 08:41 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
as long as he doesn't crimp the hose (and perhaps uses a more rigid hose than the stock stuff) he should be OK.
Old May 1, 2009 | 05:20 AM
After looking at a 300zx overflow tank(tall and skinny) I might be able to squeeze it in somewhere. I'm probably going to run the 300z windshield washer res also because its smaller and doesn't have a long *** neck.
Old May 1, 2009 | 07:32 AM
4signs's Avatar
I just kept the overflow tank, relocated washer res. and enlarged the hole for the I/C piping.
Old May 1, 2009 | 10:59 AM
I see. That will work. Thanks for the pic!
Old May 1, 2009 | 11:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
am i the only crazy one that looped it behind the front pass side tow hook in front of the alternator?
Old May 1, 2009 | 11:08 PM
maxmaxima91's Avatar
Nope.. i did mine that way to dan... no washer relocation required.
Old May 2, 2009 | 10:40 AM
4signs's Avatar
its nice to see all these boosted 3rd gens come out of the woodworks
Old May 2, 2009 | 05:33 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
sure is, especally the boosted vg's....
keep the work coming, i would personally put some ruber inbetween the intercooler and the bumper to keep it from rattling and the steel from eating the aluminum.
Old May 2, 2009 | 06:20 PM
Well I have had some help and 2 sunny days. We have been very very busy. I'll snap more pics tomorrow in the day time but heres a couple teasers.
Old May 2, 2009 | 07:50 PM
1991Maxima1991's Avatar
lol thats just what those pics are teasers lol.....looking good man i wish you lived near me so you could put a quick turbo setup on my car looks liek you could probibly do it in a weekend but anyhow nice work man i am very impressed! Also im kinda taking a liking to the baby blue valve covers ;]nice touch lol
Old May 2, 2009 | 07:54 PM
True that man ive never seen so many beautiful 3rd gens in my life! Alot more people are venturing into the turbo world and putting great setups on their 3rd gens, That is Awsome! I know that most of the 3rd gen owners would rather turbo a VE but im glad to see some of you are just making due with the VG and coming up with some very impressive numbers...Keep up the good work guys maybe one day i might turbo mine...
Old May 3, 2009 | 11:39 AM
GRNMAXDMON's Avatar
very impressive work, damn wish i had that much time to actually turbo mine already. i've been sleeping on this project for awhile now and the turbo and manifolds have been sitting in my garage for over a year. but im still debating to swap in a 3.5 VQ like Aaron is doing on his 3rd gen or just turbo my VG or swap the VQ and turbo that one??? so many choices, so little money and time. i need a new job. but keep up the good work and post a video if you can when done. i would like to hear that motor running.
Old May 3, 2009 | 05:05 PM
-ReLLiK-'s Avatar
Amen brotha! lol. Wow, me being a rookie to the Maxima world, im just soaking this all in right now. hmmm, looks like i may have a project once i get to Lincoln Tech
Old May 5, 2009 | 07:55 PM
I'm getting closer.
A little custom work
Old May 5, 2009 | 08:14 PM
looking good due. say um..... how much would it cost if, say, i wanted one of those cut-n-reversed elbows in a few months' time?
Old May 6, 2009 | 05:23 AM
mig time 35/hr
tig time 45/hr
If you cut it and its pretty much prepped(deburred)and all I have to do is weld it its $45 dollars. I've got an extra that I could cut, clean, and weld for $75 shipped.
Old May 6, 2009 | 05:58 AM
DanNY's Avatar
Ad·min·is·tra·tor
mig time 35/hr
tig time 45/hr
i say TIG it...don't MIG it.
Old May 6, 2009 | 06:01 AM
Greeny's Avatar
¯\(°_o)/¯
Nice welding skills there mang
Old May 7, 2009 | 07:20 AM
Engine is done so I go to start it up and nothing. All I get is fuel pump cycling and my headlights. Everything else is dead. I'm getting power to relay and fuse box. When I did the swap I also swapped the engine bay harness for the manual trans.. By the ecu there was an extra plug in the gxe that the se harness didn't have and I figured it was for the airbag setup so I'm hoping that this is the problem. Anyone else have this problem or does everyone just use the autotrans harness? Well anyways heres the finished engine bay. Its pretty much finished besides swapping out a few clamps that I'm waiting for. Also just bought some new 18's and paint prep will begin as soon as the rain subsides.
Old May 7, 2009 | 08:18 AM
GRNMAXDMON's Avatar
wow, thats weird it wouldn't start. did you plug in all the necessary connections for the clutch neutral safety switch and the ASCD if you are using that. but other than that i am impressed with the amount of work you have put into it in a short time and still keep it looking clean and not messy with running a crap load of wires like i have seen in other turbo setups.
Old May 7, 2009 | 08:58 AM
DanNY's Avatar
Ad·min·is·tra·tor
it's missing cruise control and looks like the AC stuff is gone.
so yeah it looks a bit "cleaner" b/c it's missing stuff.
