Rough Low Idle Speed????
Old May 8, 2009 | 03:47 PM
fotoman's Avatar
94 6 cyl Maxima GXE
I have changed spark plugs, wires and rotor and that eased the vibration and rough idling but now the rough idleing has returned with a check engine light that stays on ... the car idles at around 75 rpm under the 1 and has a noticable vibration .... what might be happening what do I need to do? What is a normal idle speed?
Changing fuel injectors is a project over my head what is a reasonable price to get one if not all replaced at a shop and what type of shop????
Old May 8, 2009 | 03:50 PM
Greeny's Avatar
¯\(°_o)/¯
Check the codes first..
how to check codes--> http://forums.maxima.org/4873104-post18.html
Old May 8, 2009 | 07:14 PM
fotoman's Avatar
Thanks this looks like something I can Do .......
Old May 9, 2009 | 12:14 AM
fotoman's Avatar
Going back to the idle speed question
Going back to the idle speed question what is the normal speed and can/should/how is it adjusted?????
Old May 9, 2009 | 12:36 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
first warm the car up and have all the accessories (a/c, radio, radiator fans, etc) offturn the screw thing on the ecu to the right (ecu is to left of passenger's feet behind black plastic cover), then go under the hood and adjust the screw on the IACV until you like the idle, then turn the screw on the ecu back to the left again. iacv is the cylindrical thing on the front-driver-side of the intake, sortof between the battery and the throttle body.
Old May 9, 2009 | 02:33 PM
fotoman's Avatar
ANYONE ....... Im a newbie so pictures are worth a thousand words to me if possible......
I know how to check the ecu but even with a clue i dont see this iacv
Old May 9, 2009 | 02:45 PM
blue circle = iacv's idle adjustment screw
red x = throttle body and sortof off-frame near the green x is the battery, as i uesd earlier for reference points
Old May 9, 2009 | 03:22 PM
1991Maxima1991's Avatar
wow didnt know it was that easy to adjust our idle speed..... nice
Old May 9, 2009 | 05:31 PM
sleepyvg30e's Avatar
if ur check engine light is on u need to do more than adjust idle i would suggest leaving it alone until u check the ecu codes first if no codes pop up (which probably wont happen) then clean the intake in this order
1 maf
2 throttle body
3 iacv
4 entire plenum
....if all that is clean and there are no ecu codes and the check engine light dissapears then try adjusting idle
btw did u adjust timing when u changed plugs wires and the rotor?
Old May 9, 2009 | 06:07 PM
Greeny's Avatar
¯\(°_o)/¯
1 maf
2 throttle body
3 iacv
4 entire plenum
http://forums.maxima.org/3rd-generat...code-51-a.html
Old May 20, 2009 | 08:31 AM
RustyMaxima's Avatar
Do u need to do anything else other then turn that?
Old May 20, 2009 | 09:48 AM
for idle adjustment? no. if your idle is rough or low though, odds are there's something else you need to fix first. like a misfire or a vacuum issue or a maf issue, etc.
captchaos
Mar 15, 2016 12:18 PM
lrb6805
Sep 17, 2015 04:49 PM
ballerchris510
Sep 10, 2015 09:35 PM
