Transmission concern......
When my car is cold, usually in the a.m. after sitting overnight, I put the car in drive with foot on brake and it "slams" into gear and sometime I hear the front tire screach. It will not happen all of the time, but I have noticed it more often. Is my trans on its way to the junk yard? Fluid level is fine and was changed about a year ago.
Thanks.
Thanks.
Thanks.
Thanks.
Agreed with Maxinout93. Warm it up some more and see what that does, unless your brakes are ****house, it would have to launch from a considerably high RPM to make your tires screach. Maybe worth checking your torque convertor if it persists?
Thanks.
Thanks.
1. worn out Engine mounts
2. TPS sensor out of adjustment
3. Bad Dropping resistor under the intake tube rite behind the battery
from Park put ur gear straight into 1 GEAR and see if it slams...if it DOES NOT and only slams in D then check ur engine mounts and resister and while ur driving if it changes gear hard from 1st to 2nd gear then check ur TPS sensor adjustment....
it could be one of these or more...
besides, if slamming was different between 1(1) and D(1) then i would suspect something involving the tranny.... not the motor mounts. the motor mounts won't cause slamming in one forward gear selection and not the other... the t/c can't put down enough power to slam/chirp at idle unless just from bad motor mounts. i know because i had this motor mount before my 5spd swap. and i had no issues that i noticed until i started playing around with the manual t/c lockup bypass thingy (which killed my tranny)
I believe i have a similar problem right now. Does your tach jump around like two little kids with Dreadlocks??
does this problem smooth out once you get everything warm?
Is it intermitten (your problem sounds worse than mine)
does the car shift funny once you get it going?
Tonight i am going out to check all the grounds, my friend suspects the computer grounds are faulty and need cleaning. I have several little things going wrong at once so the likely hood that its a sensor (tach) is unlikely.
1(1) being different than D(1) how? difference between the 2 is that 1(1) does have the low/reverse brake on, and D(1) doesn't. you figure that's what's slamming?
VE Auto...... D(1) has only forward clutch wen put in D but 1(1) has forward clutch, overrun clutch and low&reverse brake...
VG Auto.....D(1) has low clutch and one way clutch but 1(1) has low clutch, low&reverse brake then one way clutch.
were u talking about VE auto? plus u have worked on 3rd trannies many times u know better...
i had the same problem when put in D it will slam and wen put in 1st it wont really...i checked my engine mounts and they were worn out..changed them and tps was a lil out of adjustment, fixed it and slaming has since gone away...worth checking engine mounts first if they r right its internally or bad TPS...tps is cuz if it is out of adjustment its jus gonna signal the tranissmion control module that throttle is open and tranny gonna slam asuming that car is running plus if u have bad engine mounts slamming gonna be worse and over top of that by chance if u have bad dropping resistor it might hurt ur neck...
Pied
Sep 26, 2015 03:29 PM
