locks not working
Old May 10, 2009 | 06:37 PM
chrome91's Avatar
locks not working
for some reason this happens sometimes on my 92 GXE, suddenly you cannot unlock/lock the doors with the numeric pad on the outside or the regular switch on the inside. when you try you can hear a click near the dash but nothing happens. the doorpad still beeps and lights up. last time it happened was last year and after a week it randomly started working. im stuck opening the front doors with the keys and locking the locks with the keys or pushing them down
is this a wiring problem?
Old May 10, 2009 | 06:52 PM
Gunther's Avatar
http://forums.maxima.org/3rd-generat...go-unlock.html
Stickies FTW
Old May 10, 2009 | 06:58 PM
chrome91's Avatar
Search function not catching that sticky FTL
anyways, thanks for the link. if it doesnt fix itself in a week i'll try to fix it
Old May 10, 2009 | 07:15 PM
burhan92SE's Avatar
u have a crack in ur time control unit...if u can pull it out from under the dash and open it up u will see that there is crack links in there...solder them again and u will be set for another 15 years or so
Old May 10, 2009 | 09:45 PM
chrome91's Avatar
so its something i can yank out from the bottom and i dont have to remove the dash covering? the horrors i found when i removed the console and dash covers to wire up for subwoofers should never see the light of day again
Old May 10, 2009 | 10:25 PM
Greeny's Avatar
¯\(°_o)/¯
See this sticky?
http://forums.maxima.org/3rd-generat...-settings.html
Old May 10, 2009 | 10:47 PM
maximaman1313's Avatar
you remove 1 piece of dash trim, held on by a few bolts. very easy to take off. there is a black box you can pop the timing contorl thing out. on the circuit board there is commonly a bad solder point, there should be pics in the sticky. I soldered this point and my locks started working properly, then 1 year later they acted up again, turns out a bad circuit board on the driver door switch panel, both of these parts can be picked up at junk yarks for dirt cheap.
Although last time i was at the junk yard I pulled the units from under the dash on 4 maximas, and they all had the same common point of green corrosion exact same spot on all boards. very wierd.
Ive never soldered before, and by using the sticky I bought a $12 solder iron and fixed itmyself first shot.
Also don't forget the they actual timing control unit is different for models.
Im sure the VE one is different than the VG motor, not sure about se vs gxe. luckily most maximas in junky yards are gxe anyways, for you at least
Good luck
Old May 11, 2009 | 12:34 AM
burhan92SE's Avatar
Good luck
i dont think so if there is any difference in time control unit cuz if there was then FSM would have pointed out in wiring diagram...
Old May 11, 2009 | 01:37 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
for that year. what about other years for which the FSM isn't available in PDF format?
Old May 11, 2009 | 03:30 AM
burhan92SE's Avatar
is there even time control unit in 89-91?
Old May 11, 2009 | 04:20 AM
BenStoked's Avatar
Jesus was a Zombie.
yes.although, I don't think they are swappable, from 3Ga to 3Gb. there were massive changes to the wiring system, probably to accomidate the ve (or the engineers found a flaw in the initial harness).
but I definitely had to change mine out. damn thing got burned up, and kept blowing fuses. (I have a thread about it somewhere...)
Old May 11, 2009 | 07:46 AM
the units look almost the same, i believe have same plug ins, go in the same size box and are same size and all that crap.
trust me, Ive had 3 in my hand that would not work for me VE and they were pulled from VGs, I dont know what years any of the cars were as I didnt look. But I do know that I found one out of a VE and the circuit board was laid out slightly differently, I wish I took pics, but oh well.
maybe the ones that were different were the 89-91 ones like benstoked said.
Im going to try to find proof somewhere if I can and post, but I know what I saw and what they were....
Old May 11, 2009 | 10:40 AM
time control unit and door lock timer are not the same thing i don't think.
Old May 11, 2009 | 02:48 PM
chrome91's Avatar
weird, this morning the locks worked fine and ive had no trouble all day
Old May 11, 2009 | 03:07 PM
Gunther's Avatar
It's a problem similar to the clocks. They may or may not work depending on temperature and humidity, maybe how you went over a bump one time. Eventually they'll stop working altogether though.
Old May 11, 2009 | 06:01 PM
chrome91's Avatar
it happened almost right after i washed it, that humidity may have done it though i get it washed every 1-3 days and its a rare occurrence for my locks to not work. unless the lock problem happens within a couple months, im not going to rip out the time control unit and see whats up
Old May 11, 2009 | 06:58 PM
mine went from working to not working, to locking everytime i would unlock them ..all for a year, then i decided to fix it.
so even though its working again, hate to say it, but its just a matter of time before they start acting wierd again
Old May 14, 2009 | 12:20 PM
a_poole90's Avatar
my locks in my 92 arent workin either. i tried saudering some points on the time control circuit board which i thought were bad but still not working. i tried two other units out of other cars and still not working. the door lock timer is clicking but nothing happens. what else could be wrong?
Old May 14, 2009 | 07:41 PM
try the driver door master switch panel. Thats what was my problem the 2nd time.
Old May 25, 2009 | 07:01 PM
chrome91's Avatar
fail, when im up to it im going to have to fix the time control unit. this past week it constantly has done the lock thing, in 1 day it can work in one hour and the next a no go. before it was every few months for a few hours but even today it worked once in the morning and it quit now
Old May 26, 2009 | 12:52 PM
petesauto4714's Avatar
Problem is with wiring connection at drivers door lock switch...just give it a whack ...locks should now work till you can take off door panel...
Pete
Old May 28, 2009 | 09:16 AM
tonyfbc's Avatar
Does any one have a diagram of the door where the master door switch is?
Old May 28, 2009 | 03:38 PM
internetautomar's Avatar
mod or sell?
what do you mean a diagram?
the switch is right there plain as day. Even a blind man could find it, and I mean that literally.
Old Jul 14, 2010 | 07:28 PM
traxtar944's Avatar
Would be lost w/out the org
Bumping an old thread.... my door locks aren't working and haven't for quite some time. I purchased a known working door lock timer (thanks James92SE), but it just clicks like my original one. Lifting the drivers/passenger lock manually will make the timer click, and using the switch on the drivers door will make the timer click.
After reading this thread, can someone tell me what the problem most likely is? The drivers door switch unit? The time control unit?
Thanks for the help...
Old Jul 14, 2010 | 08:57 PM
chrome91's Avatar
well ive had no time to fix this issue yet lol. whats funny though is after i made this thread the keypad worked for everything but the locks, then it fully quit until a couple months ago and again it works for everything but the locks
im fine with using the key but i should try to fix this issue by August
Old Jul 15, 2010 | 04:55 PM
traxtar944's Avatar
So... nobody knows what it could be if it's not the door lock timer?
Old Jul 15, 2010 | 05:19 PM
Gunther's Avatar
not if you're selling...
and it sounds like the time control unit, broken solder joints I would guess.
Old Jul 15, 2010 | 10:36 PM
traxtar944's Avatar
Selling? Selling what??
I'll check the circuit board of the Time Control Unit for broken joints, but I'm pretty sure I did that when the problem first came about and didn't see anything suspicious...
Old Jul 21, 2010 | 08:22 AM
traxtar944's Avatar
Bump... still have the lock problem and no input from the board?
Old Jul 22, 2010 | 12:44 PM
ghostmax's Avatar
My bet is still your door lock timer...I just changed mine out from the JY bc I was getting the click, and the locks work great now.
Old Jul 31, 2010 | 06:51 PM
TRBOMAX92's Avatar
just replace the time control box thats what runs the door locks on third gen max
the forth gen its the actual driver door switch. but i can tell you 99.9% sure its the time control box.
I replaced mine for the same reason.
Old Nov 12, 2010 | 03:15 PM
Franky Cordero's Avatar
Keypad beeps, ligth on and open the windows but do not open the trunk and door locks, neither the main lock control at the armrest, no click. Already change the time control, the main control. Any other sugestion ? Thanks !
Old Nov 12, 2010 | 03:22 PM
James92SE's Avatar
2 VE's are better than one!
When the door lock timer is known to be good and the locks still won't work then it's got to be your master switch on the driver door. I spent months going through timers on my black VE (and thought they were all bad) before realizing it was the master switch. That's how I wound up with so many timers and most of them turned out to be good
Old Nov 12, 2010 | 03:35 PM
the new master switch on the driver door is working perfectly ( tested it before installing it ) What about the digital entry control unit at the front passenger door ?
Old Nov 12, 2010 | 05:04 PM
James92SE's Avatar
Dunno... I have absolutely zero experience with the GXE keypad stuff
Old Nov 12, 2010 | 05:46 PM
chrome91's Avatar
and my lazy *** still hasnt fixed this got tied up with other stuff, and im used to using the key to lock/unlock
Old Nov 13, 2010 | 03:41 PM
Problem Solved !!!! It was a crack in a soldering on the door lock timer, a drop of melted wire and fixed ! Thanks to everybody ! Now I have an additional working main door control and time control unit.
Old Dec 6, 2011 | 06:16 AM
CandiMan's Avatar
Say Candyman 5 times
Anyone have internal pics of the door lock timer, the location that commonly needs to re re-soildered? The same for the clock.
Old Dec 6, 2011 | 07:18 PM
chrome91's Avatar
i never did even end up fixing this oh well lol
Old Dec 7, 2011 | 09:56 AM
CandiMan's Avatar
This is the reason why I asked if anyone has a internal pic of the area that needs to be repaired. I have two spare clocks and a door lock timer in the storage shed and I decided to crack them open to see if I can notice a soildered joint that needs re-soildering.
To begin with, the internals of both clocks were slightly different. Notice where the pencil is pointing to.
But the external housing of the clocks were the same. No noticeable difference on the outside
Here's the door lock timer
Now it's possible, all three of the items don't need any repair. It's possible the soildered joints are not seperating. It would have been nice to notice something, repair it, install it and see what happens.
The next step is to remove my timer and clock and see if I notice anything with them. Lets see what happens.
