overheating
Old May 25, 2009 | 11:21 AM
woot's Avatar
overheating
its a 90 maxima problem is that the temp. hand climbs between the middle to the H but it only seems like it does this when going up hills reguler driving and idleing it stays in the middle.. anybody have any ideas on what it could be??
Old May 25, 2009 | 12:09 PM
maxinout93's Avatar
I would first try to replace the thermostat, since its so cheap and pretty easy to install. Then Put some fresh antifreeze in it and see if that helps. I had a problem with my thermostat in the winter. It would stay closed too long, therefore causing the car to take too long to warm up and with regular driving, my temperature hand would go all the way down to C on the scale, so i would recieve no heat at all. I changed the thermostat and that solved the problem.
Old May 25, 2009 | 12:12 PM
woot's Avatar
i have just changed the water pump,timing belt,and flushed antifreeze, it has 66000 original miles, but i cant remember if i changed the thermo..
Old May 25, 2009 | 12:16 PM
Greeny's Avatar
¯\(°_o)/¯
You need to bleed the air out of the cooling system (very common issue with the vg engine after you open up the cooling system)
When engine is cold:..Jack up the front end as high as you can get it(atleast 2ft. if possible)/remove radiator cap/start engine,let idle while you are constantly topping off the radiator as it is running,until it will hold no more..
Note: you need to do this procedure until the the engine temp needle is close to mid way(yes,sometime during the process,coolant will "burp" out of the radiator,this is normal,it is the air bubbles in the cooling system coming to the top,and out of the radiator)
Old May 25, 2009 | 12:23 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
hay greeny.. did the bypass make your car any easier to bleed this time or have you not done it yet?
woot's Avatar
it has been like 6 months since we did the water pump and everything i noticed it after putting injectors in a few days ago, i gues air got in throught the two coolant line on the intake??
Old May 25, 2009 | 12:27 PM
Greeny's Avatar
¯\(°_o)/¯
Yes...
no...
bout ready to drive it into the woods behind the house and swipe teh wifeys Z71..
Old May 25, 2009 | 12:29 PM
Greeny's Avatar
¯\(°_o)/¯
Yep, air pockets can and will develop any time you disconnect coolant lines on the vg..
Old May 25, 2009 | 01:31 PM
Yes...
no...
ok so it DID make it easier? cuz remember how easy mine was to bleed, and i've actually bled it dead level and heat worked right away. maybe i'm special
Old May 25, 2009 | 01:47 PM
Greeny's Avatar
¯\(°_o)/¯
ok so it DID make it easier? cuz remember how easy mine was to bleed, and i've actually bled it dead level and heat worked right away. maybe i'm special ED
lemme fix that for you...
I didn't loose any coolant, so i didn't see the need to bleed it..
Old May 25, 2009 | 02:22 PM
doing the coolant bypass should cause a slight loss of coolant... it did when we did mine a few years ago.
Old May 25, 2009 | 02:24 PM
Greeny's Avatar
¯\(°_o)/¯
I'm special like that..
Old May 25, 2009 | 03:38 PM
woot's Avatar
ok so i went and put a new thermo in it and ran it for 30 minutes letting all the air out but i haven't drove it yet so i will let you know the outcome
Old May 25, 2009 | 04:49 PM
nitrous360's Avatar
When you fill it you should also take out the plenum bleeder bolt. I usually leave it out and run it while filling as needed until it burps out the air and has a pretty steady stream coming out. Only thing that sucks is you leak some coolant out onto the engine. I usually put some rags around it to catch what comes out.
Old May 25, 2009 | 07:05 PM
polarisfctyrcr13's Avatar
simple but just checking, is ur coolant level low?
Old May 25, 2009 | 08:21 PM
1992maximase30's Avatar
i remember a member helping me out doing this.
i replaced the radiator.
we had her up in the air, coolant spilling out.
and still nothing.
the fans were running on high too.
i kept suggesting to remove the bleed bolt he said there's no bleed bolt on the vg.
i see this little stick beside a bolt that said : "do not open when hot".
i opened it anyway and BAM! antifreeze came out.
her temp went to normal...
Old May 25, 2009 | 08:43 PM
and still nothing.
people with aaron's spacer kit (or peopl that just bypass thir UIM coolant hoses) won't have that bleeder bolt tho. but as i stated above, i have had this bypass for 2 years, and my coolant bled VERY fast at greeny's house (and again a few months later when i replaced all my rubber hoses) without even barely lifting the car up. temps are perfect.
Old May 26, 2009 | 03:44 PM
oh i was'nt talkin bout those who use spacers...i meant oem set-up.
Old May 28, 2009 | 11:28 AM
woot's Avatar
well the car has not heated up since the thermo. and bleeding but i did notice the bottom of my radiator is leaking coolant so thats next!!!!
Old May 28, 2009 | 11:45 AM
DanNY's Avatar
Ad·min·is·tra·tor
where is the leak coming from?
you're at the car..not us.
Old May 28, 2009 | 12:54 PM
woot's Avatar
i already know where its leaking from, i wasn't asking a question it was simply a statement saying that it was leaking i have a new radiator on the way!
Old May 28, 2009 | 01:20 PM
DanNY's Avatar
Ad·min·is·tra·tor
ahhhh...ok then fix it. no use venting to us here.
these are old cars. things are going to break.
Old May 29, 2009 | 05:08 AM
woot's Avatar
yep yep old cars!!!! thats what they do
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
