*!*!*! Help*!*!*!*!*! Help
Old Nov 26, 2001 | 08:23 AM
ChrisCheezer's Avatar
ok, last night i was driving home (raining) and i guess i hit a bump but my dash lights went out, just the lights behind the RPM guage, the speedomeater,the gas,the heat, and the little green light above the stereo... ALL the other lights work. THIS SUCKS SO BAD!! ... im just prying that when i go homethey work.. some how....
plz help
** i GOT PICS OF MY MAX ** they will be up l8r
Old Nov 26, 2001 | 09:08 AM
«§»Craig B«§»'s Avatar
check your fuses first
on my page, I have a listing of what each fuse controls
find the one that has dash/instrument lighting and then see if the other functions of that fuse are working
if not, then change the fuse and it should be fine
http://www.prism.gatech.edu/~gte671n/mymax.html in the how to section
Re: *!*!*! Help*!*!*!*!*! Help
plz help
PLZ SOME ONE HELP ME!!!!!
Old Nov 26, 2001 | 09:46 AM
Re: Re: *!*!*! Help*!*!*!*!*! Help
ok, thanx alot i did not think there would be a ??fuse problem?? .... i never herd of this problem with the dash .
THANK YOU
Old Nov 26, 2001 | 10:02 AM
Matt93SE's Avatar
STFU n00b!
My guess is that you've got an aftermarket head unit in there, right?
Check behind the head unit for a loose wire. I think it's red w/ yellow stripe. that's your illuminuation wire. if that's shorting out against the frame of the car, it'll cause the fuse to blow.
Old Nov 26, 2001 | 10:12 AM
i dont have a aftermarket HEAD (hehe) but i do have some things that required a proper ground... i used the ground that the head unit bolts into .. ya know the 4 bolts .... if that came off ya think it could of shorteed out my lights???? i hope thats the problem ..
thanx
l8r
Old Nov 26, 2001 | 02:35 PM
O damn ..... nothing
i cant find the fuse/s for any instrments and i dont know where it says them on your page they still dont work .. i disconected everything/ like stock
Old Nov 26, 2001 | 02:45 PM
plz help
Old Nov 26, 2001 | 04:33 PM
Re: O damn ..... nothing
it's on of the 10A ones on the left column of fuses
I believe it's the 3rd 10 from the top
it's listed as Tail, clearance, licence, side marker, illumination; sorry I thought it said something different when I first posted
Old Nov 27, 2001 | 09:03 AM
Re: Re: O damn ..... nothing
ok dude that was the problem.. thanx a lot.. it seems that the after market guages that i bought lost there ground. and i guess that did it ... after replacing the fuse i killed another one the same way....
