JWT ecu question
Old Nov 27, 2001 | 12:01 PM
flyry110's Avatar
JWT ecu question
ok, i'm working on that TT project for my VE, i know i need fuel upgrades as well, but one of the things i defenitely need is the ECU mapped for boost. . . . One of my honda buddies was saying i might be able to get away with an FMU. if i buy my JWT now, can i reprogram it later for boost? how does that work? i already aquired an apexi fuel management controller, but that's gonna be for just looks right now. and to keep track of my air/fuel (i'm running rich for some reason). anyway, any help would be appreciated. OH, I also tried teh FAQ's and a search and couldn't find anything on this. thanks.
Old Nov 27, 2001 | 01:40 PM
Nismo87SE's Avatar
Re: JWT ecu question
Thats easy, if you bought a JWT ECU now it would be around $500-600 depending on where you get it from. After that any reprogramming minus the n2o program is $100 from JWT.
Old Nov 27, 2001 | 01:51 PM
Jeff92se's Avatar
I'm needing a caw
Why TT? A stock VE will only handle xxx psi anyway. A small single will begin spooling before 2000 rpm. If you are going to build the VE, what parts are you going to use? Especially the headgasket? Again a V6 should have plenty of exhaust to spool any small/mid-sized turbo.
Old Nov 27, 2001 | 01:56 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Originally posted by Jeff92se
Why TT?
ummmmm, so you can put the TT badges on the trunk...come on now Jeff!
Old Nov 27, 2001 | 01:59 PM
Jeff92se's Avatar
I'm needing a caw
One will do me fine.
Old Nov 27, 2001 | 04:10 PM
flyry110's Avatar
TT has just never been done. Dunk's race shop can make me the head gasket. the good thing about the VE is it's cast iron, unlike the aluminum VQ. i can run more boost. I'm looking into pistons right now. . . .
Old Nov 27, 2001 | 06:06 PM
DA-MAX's Avatar
but still why do TT if you can do about the same with a single setup....more trouble just to be unique
Old Nov 27, 2001 | 06:41 PM
flyry110's Avatar
why question? i dunno, i'd rather have 2 small rather than 1 big.
t6378tp
Sep 29, 2018 04:27 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
