Gaskets...Mounts...Manifold...
Old Aug 8, 2009 | 10:53 PM
Infam0usMax's Avatar
Ive found a set of gaskets all over the net but how many gaskets should i have to replace?
How many mount are there to replace? Are there any tranny mounts also? Ive already done the front when i should have just went ahead had them all done.
Exhaust manifold, My car sounds like there is a hole in the somewhere in it neat the front and its loud when I step on tha gas it kinda makes this clicking sound... not sure if that help but ill post a vid if needed
Old Aug 8, 2009 | 11:39 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
4 mounts. 2 on trans, 2 on engine block.
what are you replacing gaskets for? intake leaks? exhaust leaks (related to 3rd paragraph)? oil/coolant leaks? *****-n-giggles?
the exhaust thing COULD also be broken studs. and if it's rusted in place a broken stud COULD appear to be intact but in fact only be holding on by the rust. i had this happen in 2007 when removing my front exhaust manifold... one of them was already broken but the rust was just holding it in place.
Old Aug 10, 2009 | 12:04 AM
  • Well I know for a fact that oil is coming from somewhere because the valve covers are dang near black. and when i clean them off a bit it goes right back to the samething so im guessing VCG(valve cover gaskets) need to be replaced there.
  • Since Last year whe ni got the car and it was cold I figured I had an exhaust leak... So i figure why not just go ahead and replace most of the gaskets to be on tha safe side.
  • I also have been loosing coolant but to where i really dont know i did see something dripping from the side where the water pump is but im like it cant be the pump if i just replaced it. u guys told me to get a thermostat and see if that fixes that problem im getting that this week.
Old Aug 10, 2009 | 10:10 AM
doublecheck everything on that side near the water pump.. you might have to take the belts off to get a better view and everything. How new are the hoses on that side? also have you doublechecked the hose clamps? I was leaking coolant due to a loose hose clamp when i drove from raleigh (50*F) to Greeny's house in TN (~15*F). It was plenty tight when it was hot out, but apparently not in the cold.
Old Aug 10, 2009 | 11:55 PM
HERES A LINK: http://www.youtube.com/watch?v=_z-XK8aAsJc It should help explain what im asking..
Old Aug 11, 2009 | 12:08 PM
that howling is unsettling. is it maybe coming from one of your a/c pulleys? remove that belt and see if the howling still occurs.
and also does the knocking sound EVER go away? does adding oil help (oil level)? does adding oil not help but CHANGING the oil does (oil and filter cleanliness/lack of contamination)?
Old Aug 11, 2009 | 12:23 PM
I will check on that belt but that noise started a few weeks ago i just heard it a few nights ago before leaving work.
and that knocking sound does come often right now its time for an oil change i bought a K&N oil fliter yesterday im suppose to be getting my oil changed 2marrow. sometimes when the car is real hot u hear nothing and it runs smooth. but when its kinda kool out i get problems.
Old Aug 11, 2009 | 12:37 PM
i see. like mine right now clacks like a **** on startup but then shuts up... but then toward oilchange time it clacks the whole time i'm driving. Even i myself am not sure if my problem is oil level or oil cleanliness tho.
Old Aug 11, 2009 | 03:02 PM
1993-VG30E-GXE's Avatar
That exhaust leak sounds exactly like mine. You can find where it is by spraying water with dishwasher soap on the flange, and bubbles will blow where the air is coming out. There's probably no point though since the exhaust manifold gaskets will need to be replaced, surfaces checked for distortion, which means engine removal.
If your going to the trouble to fix the manifolds leak - just overhaul the engine in my opinion (depending on the mileage of course though) if after inspections it needs overhaul, that's what I ended up doing. It's so much work to remove it, that I want to avoid doing it anytime soon again.
Caped is right on the studs and nuts looking like they are intact but they are in fact brittle and fall right out. Most of the studs and nuts just fell right off when I put the socket on them, and I hit them lightly with a chisel on the side at first to work the penetrant, and they just moved. Only about half of the studs in total were intact in mine for both front and rear. There was very little clamping force left on those flanges.
Old Aug 12, 2009 | 12:51 AM
Right now im at 257k i found a block on ebay for 400+ with 85k on it thought about getting it not sure tho if i dont get that one where am i gonna find a engine for this car that is worth the money? Im to the point right now where i just want to get it to run real smooth old car but with some TLC i think i can get her running 10x better... but the problem with the sounds i hear kill me.
Old Aug 12, 2009 | 02:13 AM
Why don't you just overhaul the one you have now? Do you need it for work or something so you can't allow for the down time? It could take up to a month to overhaul - unless you get all the parts ahead of time, but then again you can't until you do the inspections.
Old Aug 12, 2009 | 11:06 AM
Yup Daily driver... and im starting college in a few weeks so there really is not gonna be time for that. Right now im just tryin to find out what is wrong and by things as i find out. Then just take it to my dads and have him install it all.
Old Aug 23, 2009 | 04:57 PM
got the oil changed but now having the other prob thats posted in my other thread... but here is a pic of my front mount and manifold
Old Aug 23, 2009 | 06:17 PM
kringle03's Avatar
Sure looks like your exhaust manifold is cracked... The exhaust leak your hearing could be coming from the manifold gaskets, the crush gaskets on the Y pipe, or the flex section of the Y pipe, but just based on the sound of it I would say manifold gaskets.
The howling sounds sound like a vacuum leak somewhere?
Old Aug 23, 2009 | 06:55 PM
i don't think that's a crack... just a casting imperfection
and don't you see his missing exhaust stud on the right side? that's where the exhaust leak is coming from!
Old Aug 23, 2009 | 07:53 PM
kringle03's Avatar
Yeah I saw the stud... hence the inclination towards the manifold... He could be experiencing a number of leaks though, that's why I mentioned the other areas... I know personally I was, and I ended up just replacing it all including all of the studs...
Are the manifolds casted aluminum?
Old Aug 23, 2009 | 07:59 PM
iron i think
Old Aug 23, 2009 | 09:44 PM
iron i think
I thought i had more pix but ill take some more on the next day i have off...fron and rear if i can get a good pic of the rear... Caped can u check out my other thread and see if u know where tha tranny fluid if coming from? thnks again man
Old Aug 23, 2009 | 09:48 PM
what thread?
Old Aug 24, 2009 | 12:27 AM
Man those engine mounts are in good condition. Mind if I jack them from you?
Old Aug 24, 2009 | 12:17 PM
what thread?
this one http://forums.maxima.org/3rd-generat...eleration.html I remeber u said i some sound was coming from a vac line but i got an even bigger porb now with tanny fluid everywhere.
Well The from mount is brand new but my rear mount is done... i can tell from how the engine lifts up and just leans back towards the firewall... my tranny mounts look ok to me tho...
Old Sep 8, 2009 | 07:15 PM
GOT MORE PROBLEMS...Can u guys give me some good info on whats burning from under my car? its no longer tranny fluid... got that prob fixed for the most part but umm... Its seems that im missing two studs/bolts in the from manifold where can i get some new ones? and oh yeah can that be tha cause of power lost?
Old Sep 17, 2009 | 12:19 AM
Found out its two studs that are gone but im pick up 6 of them 2marrow are they hard to replace or do u just take the old ones out and put the new ones in?
Old Sep 17, 2009 | 05:57 AM
kringle03's Avatar
You'll want to do all of them, and yes having busted studs can cause performance loss... Are they "hard" to replace? Well that will get you varying answers, and depends much on you and your skill set...
Read this thread... about replacement: http://forums.maxima.org/3rd-generat...-manifold.html
Old Sep 17, 2009 | 07:07 AM
BX-NY-MAX's Avatar
Old Sep 17, 2009 | 11:35 PM
thanks for the link is there any type of lube or something i sould buy also so they dont rust like the old ones?
