STS mods ???
Old Aug 11, 2009 | 08:04 PM
GAMERA30's Avatar
From: Long Beach, CA is where i live. Queens NYC is always home.
STS mods ???
OK .. i searched everywhere... I learned Pacesetter dont make em no more and heard 4th gen STS can be modded to fit ... can anyone confirm this and is there a write up on it ???
Old Aug 12, 2009 | 04:23 AM
BenStoked's Avatar
Jesus was a Zombie.
caped stuck his stock one in the in the oven, and moved the pivot up, towards the shifter ****. essentially a sts.
Old Aug 12, 2009 | 11:18 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
NO I DID NOT!!!!!!!!!!!!!!!!!!!!
i moved the ball DOWN!!!!! that changed the leverage ratio. THEN i chopped some of the stick off. Moving the ball UP makes the swing angle really small to shorten shifts. Mine has a larger swing angle but still shorter throws.
Old Aug 12, 2009 | 12:24 PM
Cliff Clavin's Avatar
Way out West
found it in less than 30 seconds
Old Aug 13, 2009 | 10:45 AM
maxitech's Avatar
I, too, put mine in the oven and moved the ball down over three years ago...Still works great and it was free! There is no difference between what I did and an aftermarket STS, only the position of the ball differs.
Old Aug 14, 2009 | 07:25 AM
GRNMAXDMON's Avatar
well, i guess its time for this mod. im tired of the semi-truck shifter look.
Old Aug 14, 2009 | 09:35 AM
maxitech's Avatar
It is still very tall, the throws are just shorter. If you want to go all-out, move the ball and then cut an inch or so out of the middle of the shift rod and weld it back together.
Old Aug 14, 2009 | 09:52 AM
GRNMAXDMON's Avatar
don't like to cut and weld but as long as its shorter than stock i'll be happy.
Old Aug 14, 2009 | 11:03 AM
then do a big ol' S-bend like the mustang shifters had. that'll shorten the height and move it closer to you. My sts causes me to have to lean forward AND lock my elbow to get into 5th gear. It gets kinda tiresome after a while, and i sometimes miss shifts simply due to laziness (ie not feeling like leaning forward)
this is what i REALLY wanted... but i don't have anything to bend it with.:
Old Aug 14, 2009 | 01:19 PM
300zmax's Avatar
a torch, a bench vise, and a good long pipe or box end wrench, just dont slip and hit the red spot. sand and paint to finish. i planon doing this so if wanted i will take pics when done.
one question why would you want to move the ball down that would lengthen the shift wouldn't it or is my thinking that far off
Old Aug 14, 2009 | 06:19 PM
i tried, and failed.... didn't have the proper tools, so i gave up.
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
