Performance Air Filter??
Old Sep 10, 2009 | 11:54 PM
maxinout93's Avatar
When I bought my 93 vg max, it had a stock air box. I then changed it to a small cone filter and got rid of the stock air box. The guy at autozone told me I would loose gas mileage, and that the cone filter would make the car sound different vs a K & N Air filter. I like the sound of the car as it was with the stock air box and filter, I really only hear the difference when I rev the car above 2500rpms, basically I like the sound of the engine without the present cone filter, and am thinking about getting the K&N filter since it would'nt change the sound of the engine!
Old Sep 11, 2009 | 04:50 AM
BenStoked's Avatar
Jesus was a Zombie.
k&n does change the sound of the engine, or more correctly, the intake.haven't you ever seen a k&n commercial?
Old Sep 11, 2009 | 11:56 AM
maxinout93's Avatar
nah I havent seen the commercial, but the K&N filter would fit right inside the stock air box housing.
Old Sep 11, 2009 | 12:07 PM
btrig1990's Avatar
I installed the K&N on my VG30e and yes it does change the sound of the motor, slightly. You can hear more air going through but you dont get that cowl suction sound that short rams get.
But I also took the intake plenum out and there is a section (the resonator) that goes through a hole in the engine bay and it dips to a little bit in front of the fender. I cut the bottom of it so its sort of like a cold air intake, and then closed off where the plenum takes in air behind the headlight. It sounds much more agressive with this and is actually smoother.
Old Sep 21, 2009 | 04:27 PM
Stwodahorty's Avatar
i changed mine to a cone filter, and even with the hood closed, you can hear air being sucked haha.
Old Sep 21, 2009 | 05:34 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yea same on mine. i like having the extra bit of noise.. makes it easy to shift on sound alone, rather that having to look at the gauges. my brother's 6th gen has a stock airbox and is SO quiet i have a hard time hearing the RPM of the engine while shifting.
Old Sep 21, 2009 | 05:49 PM
cobradb's Avatar
unless K&N has changed they are full of holes,, look thru the filiter toward a light or the sun and take note of what you see,, hopefully they have changed but i doubt it.
Old Sep 21, 2009 | 06:53 PM
BenStoked's Avatar
Jesus was a Zombie.
yes, I have. yes, before a recharge, you can see light somewhat easily thru it.
not so easily after.
now, look thru a fram filter. ...
ZOMG!!! YOU CAN SEE THE SUN!!!!
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
