Injector readings
Old Oct 11, 2009 | 08:24 AM
W00dface's Avatar
Injector readings
Anyone know what the readings should be for the injectors? Searched and couldn't find.
Think mine are a bit shot. Im getting 12ohm on two, 100-150 on another two and around 40-50 on the last two
Shouldn't they all be around 12-13 ohm?
Old Oct 11, 2009 | 08:48 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yea yours are fawked. unless the pins are dirty and your multimeter isn't making a good connection when you were testing them
Old Oct 11, 2009 | 09:03 AM
W00dface's Avatar
I cleaned them all off before testing and the conections seemed good.
Off to the brakers I go tomorrow then. At least I might solve the problem of it running a little rough now.
Old Oct 14, 2009 | 05:29 AM
W00dface's Avatar
OK now im a little confused....
I have the VG30E in my UK SE. The injectors have black dots.
According to some websites I have been on (an I think i read it somewhere here in the forum) I should be using yellow dotted injectors.
Also anyone know if my injectors were used in any other nissan as I have trouble getting parts over here.
Old Oct 16, 2009 | 05:32 PM
jona571's Avatar
should be 10 to 14 cold lower numbers hot higher numbers se dohc takes the red injectors and I believe the sohc takes the yellow or brown color injectors as far as I know,I just had this problem with bad injectors one read 73.2 and one read 24.5 I relaced them both and my car runs great with plenty of power even with 200,000 on the clock and I still have to replace 2 coils that have 2 cracks each
Old Oct 19, 2009 | 08:15 PM
wcpierson's Avatar
Ive been trying to research this also..I cant seem to find a write up on testing the injectors and what the normals should be. I have a 1993 GXE SOHC and I have some low rpm hesitation issues. Also the car always smells like gas. Im trying to figure out what is wrong with my car and I was told the injectors were a common problem in these cars and I need to figure out how to test them. Can someone post any advice or links for me to read up on. Please
Old Oct 20, 2009 | 06:24 AM
internetautomar's Avatar
mod or sell?
if the car smells like gas you need to pull the intake manifold and replace ALL your rubber lines in the engine compartment.
Old Oct 21, 2009 | 05:57 PM
jona571's Avatar
crack coils>need imput also
I have 2 coils with 2 cracks each, is this arcing in the plug area cos my car seems to run fine even with the cracked coils,so do I need to replace these anyway??
Old Oct 22, 2009 | 06:16 AM
mod or sell?
at the very least you should fill the crack with silicone and wrap the coils in electrical tape.
Old Oct 23, 2009 | 04:37 PM
jona571's Avatar
ok thanks so the cracked coils are not working 100%
Old Oct 24, 2009 | 08:51 PM
mod or sell?
correct
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
