keyless entry problem
i have keyless entry installed on my power door locks.. but now only the lock function works.. if i pull the door lock up manually then it works. any help would be really appreciated thanks
1994 maxima (fully loaded) |
Door Lock Actuator or Timer.
Do the factory lock / unlock still work? Could be a wire not making connection as well. |
same story with factory locks (unlock dosent work when pressed but lock works.. also if i use the key or manually pull up on the lock it works..
any suggestions how i go about fixing? |
Its the timer circuit, its gets broken solder points. Its the small box next to the factory alarm, under the dash to the right of the steering wheel. You can pull it apart and heat all the solder points.
1991 maxima
How do I get combination for door entry
you don't you need to read the stickies for instructions on how to reprogram it.
I have the factory keyless entry & the passenger side lock command doesn't work. I have owned a lot of Fords & thought it was wierd that the Nissan even had a passenger side keypad...
if the only thing not working is the lock command, then you probably need a new keypad
Is there a way to completely turn off the keyless system alltogether? When it gets cold out my key pad doesn't work (on the driver side), and I have to use the keypad on the passenger side to get in the driver door. And when I put the key in the driver side door, something is preventing me from turning the key to open it the old fashioned manual way.
Want to convert it to the old fashioned manual way. |
fix your door lock and it works normal whether there is a keypad or not
How do you take the door lock timer mechanism from its mounting place under the dash, is there a certain wrench or screwdriver to use?? Also what does the keyless entry controll thing do thats located near the passenger side glove box?
Just purchased a 1991 maxima gxe, 35,000 miles. When I try to lock the doors using the lock button on the keyless entry, all the locks do go down, however, they immediately pop back up again. Does anybody know what the issue could be? There is no key in the ignition when this happens.
This is not a keyless entry issue. My car is doing the same at times. I have been patient and eventually it stops. I assume it's a front door switch or lock issue.
Originally Posted by Darkwing48
(Post 9102898)
Alot of times its the door lock timer that causes lock to work and not work at tandom or not work at all but in your case with the locks popping back up sounds like an actuator issue.
Originally Posted by ac max 92
(Post 9102934)
Could you post a picture of what a 35k max look like?
2 Attachment(s)
here are a couple pics taken by the gentleman i purchased the car from..better than the pics i could've taken:)
© 2024 MH Sub I, LLC dba Internet Brands
