Sunroof glass adjustment
Old Apr 20, 2010 | 05:57 PM
nitrous360's Avatar
I recently swapped out my cracked sunroof glass. Problem I'm having is when I took the old glass out there were only a couple shims, so I put the same shims in with the new glass and it wouldn't sit flush with the roof in the closed position. What I had to do is have no shims towards the front and like 5 shims on the rear. Problem with this is I barely can catch any threads with the bolts and it just doesn't look right to me. It operates perfectly this way but it doesn't make sense since I swapped out the glass with the same. Is there another adjustment I'm missing which would raise the back of the glass? I'm lost for ideas here.
Old Apr 21, 2010 | 05:32 PM
93SCMax's Avatar
98 SE
Just a hint, my 93 GXE SOHC has one shim on each side in the rear for the sunroof. All may be different, but five shims seems excessive. Shims should be used to adjust the height so the sunroof is level with the roof.
tarun900
19
Dec 20, 2021 06:57 PM
bigdogsteve
Jan 31, 2018 04:18 PM
jonreidhead
Jan 6, 2016 09:38 AM
leatherneck
Sep 30, 2015 09:16 PM
