A few issues with my 3rd gen
Old Sep 26, 2010 | 01:03 PM
Maxtastic GXE's Avatar
What's up I have a 1993 GXE, while my last trip to Anaheim and back (which I got 405 miles on a full tank,driving an average of 65-85mph on I5) the cruise control light started to blink several times n I lost cruising mode,which also the speedometer stopped working at the same time. Then the speedometer would start to work n cruise control was working again after I reset the speed. I was thinking its the "speed/revolution sensor" where is it located?
Also I couldn't get the "low fuel" light to go on even if the needle was way below the 'E' any ideas what it might be. Thanks in advance.
Ernest
Old Sep 26, 2010 | 07:22 PM
jbbons25's Avatar
I think the correct part you're looking for is the speed sensor. For the VG models, it is located on the transmission near the oil filter.
I may suggest reading the FSM to start troubleshooting the cruise control.
http://www.nicoclub.com/FSM/maxima/1994/
Cruise control starts on EL-113.
As for the low fuel light problem. Either the light on the instrument cluster is burnt (which I doubt) or the low fuel sensor inside the tank doesn't work. Had the same issue on mine but when I changed the fuel meter in the tank which also has the low fuel sensor it worked again.
Old Oct 2, 2010 | 06:27 PM
Thanks,I'll look into this sunday.It must be the fuel level sensor,cause I've change my cluster to the white faced one.
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
tnewbs
Aug 28, 2015 10:15 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
