Upgrading to Optima Battery...
Old Jan 29, 2011 | 11:05 AM
Infam0usMax's Avatar
I'm upgrading my battery to a yellow top optima battery. Why? because I've killed 4 alts within the past two years I now have a small Economy battery which I believe is part of my problem... Im also going to replace the batter cables because they are exposed in more than one place. the connection to the alty I have no idea about but its looks pretty good. here are my questions...
Q1. What gauge wires do I use/replace the old ones with?
Q2. The Alty's I were getting cost like $80 I'm also upgrading to one that's $130... Good idea yes or no?
Q3. Is the optima battery the best way to go?
Im going with the yellow top because I can get it for the red tops price...
Old Jan 29, 2011 | 12:32 PM
Altec's Avatar
What kind of electronic stuff are you running on the car.
Overloading the alternate will kill them. As well a bad connection will.
You don't need a deep cycle battery. I don't recommend it. Get a red top, or just get a normal sealed battery with a nice warranty. If you were driving a big diesel that needs to drive a bunch of gear a deep cycle is the way to go. In a four door, not so much.
Check your wires going from battery to ground, battery to starter, and starter to alternator. If they are corroded clean them. I would split the covering about a inch back to see if the core has corrosion. I've seen wire that had corrosion FEET into the wire. Factory gauge wire is fine.
A full size battery can't hurt. Just make sure you have room. My GXE has a full size.
Rebuilt alternators blow these days. A new one is the way to go, and a higher amp one can't hurt. Just don't be one of those dinks who puts a semi alt on your car.
Old Jan 29, 2011 | 05:34 PM
Hectic's Avatar
Q1: You can use the stock wiring if you're using a stock 90a alternator. But if you're set on replacing it, go with 4 awg at the very least.
Q2: Totally depends on what you're spending $50 more for. If it's for another basic rebuilt stock alternator, then it's a bad idea, if you're getting a high output alt. then it sounds like a good deal to me.
Q3: No, Optimas are foolish in most cases. There are those who do need to mount batteries in the trunk or in odd positions, in that case it makes sense to use a gel cell. Otherwise, you're getting a battery with a lower reserve capacity than a lot of other standard lead acid deep cycle batteries which cost half as much as an Optima. If you look around Google you can find a lot of cases where Optimas have failed prematurely, Which is compounded by the fact that the warranty SUCKS!
Save yourself some cash and get a normal battery. I'm hoping that you tested all of these alternators before assuming they were fried, because it sounds to me like you just have a temperamental battery.
Old Jan 29, 2011 | 07:45 PM
doubleclutch92's Avatar
I have had my red top since '06. Its doing pretty good. Had my alternator take a dump on me about 50 miles away from home. Made it home on the battery its self. I have a friend that works at a parts store so I get really good deals. Got mine for $90.
Old Jan 29, 2011 | 11:02 PM
Im running a Jensen Flipout, JVC 600w amp, and 2 12" sonys... I think its cause by a bad connection somewhere because the amp use to just stay on and i could figure it out so i replaced all the wires running to the amp and it was good after that now its something else i guess. and thanks you just explained what I was going to ask next about the corrosion and what wires to check thanks...
Old Jan 29, 2011 | 11:13 PM
The "new" really isnt new now that i read it
Bosch Professional Preferred Remanufactured Alternator
that's what it says... and its cost is $130 and it is just 90amps comes with a 2yr. warranty which is good.
Now I can buy a new one for $148 comes with a 90day warranty... and that one is also 90amps
Yeah i have tested them myself and took them to the place where i got it and have had them replaced because i came on here and got info on how to test the alty myself and they said to pull off the cable and see if the car still runs and sure enough it did it died meaning it was running off the battery.
Old Jan 30, 2011 | 11:45 AM
shiloh51933's Avatar
Yeah you might want to get an OEM alty or maybe a Bosch alty...the battery you might want to go with would be something with more CCA(cold cranking Amps)/CA(cranking Amps). Replacing the cables with new is always a good idea... you might want to check your accessory belts tension(2 loose or 2 tight=No Good), just to make sure. Good wrenching.
Old Jan 30, 2011 | 04:44 PM
Hectic's Avatar
You test the alternator by checking the voltage when the engine is running, not by pulling battery terminals. Should read about 14v on startup.
Old Feb 8, 2011 | 10:26 PM
New alty, and optima redtop installed, oil changed + k&n oil filter installed... new spark plug wires but old spark plugs?... hmm... My RPM is jumping like crazy it is right under the 1000 mark and bounces from there to 0mark is this cause by the spark plugs?
Old Feb 8, 2011 | 11:01 PM
elusivemax93's Avatar
Maxima engines regardless of vg or ve idle at 600-800rpms once at operating temperature. Type of spark plug being used?
Old Feb 9, 2011 | 06:38 AM
GRNMAXDMON's Avatar
Check your ditributor cap for cracks and check condition of rotor as well. Change spark plugs with NGK's only. Stay away from from BOSCH plugs as they will cause horrible engine operation on these cars.
Old Feb 9, 2011 | 09:02 AM
I'm running ngk iridium plugs myself. Yeah like grnmaxdmon said stay away from bosh
Old Feb 9, 2011 | 04:52 PM
Well what does it mean when it drops below 6 and all the lights get dim...? and the car just shakes?
Ill check that cap 2marrow morning im not sure if that what it is tho. I have NGK vpower spark plugs... I bought the Iridium NGK's today Im gonna replace them 2marrow also... should I just go ahead and replace the ditributor too?
Thats what I bought today... trying to get this thing running like a champ... again.
Old Feb 12, 2011 | 01:27 PM
maximaman1313's Avatar
To the person who said optimas tend to fail prematurely...
I can agree with that, in the last 9 years, I have had 2 optima red tops. I have a 1500w JLaudio amp and 12"JBL subs that suck alot of juice, which is why I thought the better brand would be best, so I bought red top.
The first one I had lasted me about 6 years before it wouldnt hold a charge. The second one I bought lasted me 2 years before it wouldn't hold a charge. So now Im going to just buy a normal full sized battery. My maxima has been sitting in the driveway for almost a year now . But I'm getting back to it and will have a new battery this week, replacing the front koni struts with kyb gr2 in 2 weeks. konis make it sit lower than gas struts would.....
Anyways just stick with a basic battery, but dont cheap out and get the smaller batteries, get the full sized ones, around $100
Old Feb 12, 2011 | 03:08 PM
What kind of alty you got? Regardless of the battery brand 2 years is way less than average life, you should have atleast got 4/5 years. With all that audio equipment I would hope you upgraded your alty.. Batteries usually don't matter that much unless your running something that requires more power than stock or you live in a cold environment year around.
Fbana41
Aug 29, 2016 12:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Dasmith
Sep 23, 2015 08:28 PM
