Aluminum Radiator
Old Feb 10, 2011 | 01:52 PM
Augustus Maximus's Avatar
Aluminum Radiator
I was sneaking around eBay when the aluminum rad got my attention...should I give it to the old girl?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Feb 10, 2011 | 02:17 PM
sanford7575's Avatar
Aluminum Radiator
Why that one? I saw some on ebay for as little as $25?
Old Feb 10, 2011 | 02:18 PM
elusivemax93's Avatar
Invest in a good radiator not one off ebay bro. I say a koyo radiator.
Well they used to make koyo radiators for our maximas but not anything listing now on there website.
Old Feb 10, 2011 | 03:57 PM
BklynsmoeVE's Avatar
I was jus about to buy an aeon rad..I believe the tank is plastic..I'm not famaliar with the consequences or if its a big deal..( anybody? )
Its about 75 dollars for the Aeon rad.. I think thats a reasonable price I mean its not cheap nor too expensive..what you guys think? This one could be just as good as a 150 dollar one no?
Old Feb 10, 2011 | 04:04 PM
James92SE's Avatar
2 VE's are better than one!
Eh.. I run the cheapest radiators RockAuto has with no issues in Texas heat.
What's the point of super expensive ones? Just so that the plastic end tanks don't break 5-6 years down the line?
Old Feb 10, 2011 | 04:27 PM
Oh wow rly I was afraid someone was gna tell me the plastic can't withstand too much heat but I can't imagine ny gettin hotter then texas..
Yeah tho anyone know the point? Do aluminum ones last A LOT longer? 6-7 years from now I don't mind replacing my rad again
Old Feb 10, 2011 | 04:59 PM
James92SE's Avatar
Usually super high end all aluminum radiators are found in super built cars but I don't understand the point for a non-hardcore built 3rd gen
Old Feb 10, 2011 | 05:01 PM
coolsun's Avatar
Alot of us are running the ebay ones, so am i. They are great and i don't see much of a big difference to an aluminum one unless your running a turbo. My oem copper one lasted a good 17 years though until the top started to leak.
Old Feb 10, 2011 | 05:52 PM
Ahh I feel a lot better bout my radiator purchase. I was actually thinking the samething you guys just mentioned bout stock built and turbo talk..
Other then the upper and lower rad hoses I was considerin changin my thermostat too since its about time...would the coolant temp sensor sorta be in the same area of labor as what I just mentioned or totally diff location? Id like to see if it improves my idle
Old Feb 10, 2011 | 06:05 PM
There are two coolant temp sensors one for the ecu and the other for the gauge. Right by the throttle body. Next to the fuel injectors.
Old Feb 10, 2011 | 06:53 PM
Thanks elusive, are you famaliar which of the two typically cause that idle problem or Its recommended to just replace both..
I'm assuming both sensors are by the tb...next to the f.i's
Old Feb 10, 2011 | 07:08 PM
maximo018's Avatar
I have a genisis all aluminum radiator. Here http://www.genesisautoparts.com/prod...571X7161aa.htm
Old Feb 10, 2011 | 07:12 PM
Niether really effect the idle unless the one that is for the ecu is bad then the computer goes into fail safe mode to protect the engine from destroying itself. Idle could be that sensor, iacv, vacuum leaks. Depending on which transmission you have makes the difference on the vacuum hose routing as there are a few vacuum hoses under the intake plenum.
Old Feb 10, 2011 | 08:37 PM
How's the fitment with the fan shroud and such.
Old Feb 11, 2011 | 01:27 AM
I am having my nissan parts guy find me a upgraded one for once I drop in the built engine I'm about to start on. Rather not have an engine damaged due to insufficient cooling system with a boosted engine.
Old Feb 11, 2011 | 04:29 AM
shiloh51933's Avatar
You already know...never go cheap when it comes to High Performance Parts.
Old Feb 11, 2011 | 07:27 AM
And the retainer(s) that goes into the mounting bracket(s) is susceptible to popping off. The VE30DE is a unique engine that had the shortest production off the Nissan line. I think it qualifies for something better than a $2 radiator .
Old Feb 12, 2011 | 02:45 AM
maximo018's Avatar
Actually it was fine from what I remember. Went in without a hitch. Its worth getting if you really want an all aluminum radiator. I know by the price and everything it seems too good to be true, but so far so good for me.
You can kind of see it installed in the my engine bay
Old Feb 12, 2011 | 06:02 AM
Totally sweet
Old Feb 23, 2011 | 08:14 PM
Well boys in the end I decided I wanted more for my money so I added fifty bucks and bought a 6 ton shop press, an electric impact wrench and a $29.95 eBay radiator ($59.95 shipped).
I just took delivery of the thing and guess what...it's all copper, there is no plastic anywhere on it. It's painted all black so I doubt the seller realize. Yes I scratched the paint to confirm my suspicion . Looks neater than the aluminum version as well.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
lux97Max
Sep 28, 2015 11:18 PM
jchronis2552
Sep 23, 2015 04:57 PM
