5th gen subwoofer
Old Feb 13, 2011 | 05:39 PM
xX4DSCXx's Avatar
5th gen subwoofer
so i was wondering if it was possiable to wire the stock 5th gen subwoofer into my car? and how would i do it?
Old Feb 13, 2011 | 06:01 PM
BenStoked's Avatar
Jesus was a Zombie.
haven't heard it being done before.
more info on the sub is needed...
edit: here is what I see: yeah, it can problably be modded to fit.
concern is making it work. Bose (and most high end factory audio) doesn't comply with "normal" audio equipment standards. usually, the oem speaker is impedance is weird, a 3 or 5 ohm line. amps usually use 1, 2, 4, or 8 (or any multiple like that). there is a potential concern for amp integrity when using an off-standard impedance.
so you can make it work, but would it be worth a little extra trunk space?
edit2:
dangit, we need a strike thru option..
anyway, if using an aftermarket head unit, and using the 5th gen sub/amp combo, then the first edit is pretty much useless.
wire the amp for power, and use an rca out from the radio. should work fine.
still looking, to make sure that's right.
Old Feb 13, 2011 | 07:34 PM
maximo018's Avatar
I'm thinking on replacing mine. Now remember its an inbase sub so it needs to be an open setting to work properly. Should be able to be done.
Old Feb 13, 2011 | 08:50 PM
04vqmaxsl's Avatar
I don't think it would give enough bass to make it worth it. Just go after market and be done with it.
Old Feb 14, 2011 | 10:03 AM
xX4DSCXx's Avatar
yea i have an aftermarket deck.
Old Feb 14, 2011 | 02:15 PM
krashkid0305's Avatar
Get a rockford 6.5" sub build a small box and mount it as an assembly to the rear dash then get a small amp and tada! Trunk space and some bass =)
Old Feb 14, 2011 | 05:17 PM
xX4DSCXx's Avatar
i cant seem to find one.
Old Feb 15, 2011 | 09:47 AM
Let me talk to my boss. Ill get u the rf part # and a price through us. I know he does shipping all over so if its reasonable ill see if I can get it out to you.
Old Feb 15, 2011 | 06:54 PM
xX4DSCXx's Avatar
really?! that would be really cool man thanks!
Old Feb 15, 2011 | 08:13 PM
Rods03Max619's Avatar
yeah a single 10" or 12" and you still got plenty of space in the trunk...
Old Feb 15, 2011 | 08:51 PM
ok some slight bad news. we dont get 6.5's theyre 8's. p/n P1S48 we just upgrade them. ive personally never done the install here but i see the 8's comin and going like crazy. if you want i can get you the specs and what he recommends for an amp and pricing if youd like. but some good news for you...i KNOW that JL made a 6.5" sub for factory replacement. idr if it was an W0 or W1 but thatll give you alil info to look for at least lol
Old Feb 16, 2011 | 10:56 AM
xX4DSCXx's Avatar
ok that would be nice. thank you.
Old Feb 17, 2011 | 09:38 AM
Ok so ur best bet is to go thru ebay. My cost plus flat rate shipping is about 85. If you plan on going thru me that's kewl cuz ull gain warranty access but ebay has them for like 15/20 cheaper. Sorry I culdnt get a better deal for u dude
Old Feb 27, 2011 | 05:40 PM
xX4DSCXx's Avatar
oh its alright man. thanks for checkin it out for me!
Old Mar 2, 2011 | 07:07 PM
Chris Gregg's Avatar
Get Off My Lawn
Just a suggestion from personal experience, adding a sub to the rear deck seems a bit complicated considering other options such as just putting a sub on the trunk. Don't want to do that? Okay, just get two 6x9 subwoofers for the rear. My two Kicker Comp 6x9's sound as good or better than my 8" Kicker in my 5.5 gen. And I've even sealed the 8" to achieve better bass (yes it's still mounted in the stock location).
MAXSE5SPD
Sep 17, 2022 04:00 AM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
