Heat Guage
Heat Guage
My 89 SE heat guage acts up all the time. The needle goes all the way up into the overheating zone and then just drops down. If I tap on the guage cover it will also fall back into normal range. Is this a common problem since my car is not overheating. If so, what is the repair?
Ken
Ken
well you can try replacing the gauge temp sensor it maybe bad..the gauge inside the car maybe bad might have to get a whole new cluster assymbly.not sure if you can just replace the temp gauge or not..
Wouldn't hurt to check your coolant level. the sensor for that is in the very top of the engine, so if you're low on coolant, it can do stuff like that.
If it's actually in your gauge, I have no clue there.. probably be bext to buy a gauge cluster from a junkyard and swap the gauge/odometer.
tarun900
19
Dec 20, 2021 06:57 PM
