vg to ve swap?
I currently have a 94 VG30E maxima, I am thinking about swapping to a VE30.
What all will I need to change? I know the transmission will bolt to it, so I wont need to change that, or the axles. But other than that, I have no idea. |
theres a few threads on it, you have to redo/swap a bunch of wiring as well. a few people have done it though, you could just as well boost the VG though and have good power for generally the same amount of work
First of all, why would you want to do a VE swap and keep the crummy VG tranny?
Look up the threads by Augustus Maximus, he did a VG to VE swap |
As Jeff mentioned, I would recommend changing the transmission too. Unless you rebuild it with high quality parts, the VG auto tranny is too weak, even for the VG engine itself. The tranny on mine has been rebuilt twice and when it goes out again, I'm considering doing the VE auto tranny swap.
Because the vg in the car is full of headaches, I don't want it for power I just want it reliable. I have the s13 to go fast in.
It just hit me. I don't think there's a drive plate that will bolt the VE engine to the VG auto trans. So you may have to look on that issue if you want to keep that trans.
there is'nt. many have tried...actually many have tried to bolt the ve tranny to the vg engine.
Only works if you put the ve 5spd ttranny to the vg motor. Not the A/T.
***Heart breaks***
Originally Posted by 1992maximase30
(Post 7992638)
Originally Posted by maximo018
(Post 7992840)
Originally Posted by chrome91
(Post 7993177)
you can use a VE AT with a VG too with a little modding
(Post 7993177)
Originally Posted by IThaJokaI
(Post 7982147)
Originally Posted by BenStoked
(Post 7993263)
somebody sorted out the wiring?
EDIT: Went back to my log to double check and turns out that there are three extra wires that go from the TCU to the ECU. I need to check on that. |
(Post 7993263)
(Post 7995918)
a couple people have done it :gotme:
© 2024 MH Sub I, LLC dba Internet Brands
