Stock Maxima specs
Old Nov 8, 2000 | 09:51 PM
texasimports
Can anybody tell me the stock specs on the Maxima. 0-60, 1/4 mile, skidpad, etc. I am trying to put together a comprehensive specs area for most imports. I want specs that are as realistic as possible, not what Moter Trend tells us. Thanks in advance
Old Nov 8, 2000 | 10:26 PM
FAST4EN's Avatar
Well do you want the stats for the SOHC VG (162hp) or the DOHC VE (190hp) engine? The "SE" trim from 92-94 came with the VE engine. All other 3rd generation maximas (89-94) have the VG engine.
Times:
VG Auto: 9.8 Sec ~160hp 1/4: 17.3 Sec
VG 5spd: 8.0 Sec ~160hp 1/4: 16.3 Sec
VE Auto: 7.6 Sec ~190hp 1/4: 15.9 Sec
VE 5spd: 6.7 Sec ~190hp 1/4: 15.3 Sec
From MaxFAQ website:
The all-new SE-level engine remains a 3-liter alloy-over-iron V-6 similar to the SOHC VG30 series introduced in the '84 300ZX and still used in the Maxima GXE. But this potent offering is different enough to merit its own VE family designation. The VE30DE utilizes much common technology found in the present DOHC VG30DE (those suffix letters, by the way indicate dual cams and multipoint injection) engine of today's 300ZX. That includes variable valve timing and a direct ignition system, However, the VE shares no major common components , and its camshafts are driven by chains rather than belts. The engine block is stronger with greater rigidity, but the larger heads have their four valves per cylinder splayed at a relatively narrow 30 degrees to allow the package to snuggle transversely under the Maxima's hood. On SE's fitted with a manual transmission the engine also gets a variable induction system that enhances mid- and high-range power. To improve the noise/vibration/harshness characteristics it rests in a new strain of fluid-filled motor mounts.
These Numbers are from the MaxFAQ website.
http://web2.airmail.net/scutchen/max_faq/
Any questions, please feel free to ask me or anyone else here.
Old Nov 8, 2000 | 11:00 PM
Mike S.'s Avatar
hmmm.....
The VG 5sp sounds about right...but a Auto VG is much faster than 9.8......more like 9 flat...which really isn't that fast. BUT still not 2 seconds off the 5sp. More like 1.
Mike S.
Old Nov 9, 2000 | 12:31 PM
flyry110's Avatar
Re: hmmm.....
road and track tested the 92 SE and said it does 0-60 in under 7 seconds
Old Nov 9, 2000 | 12:33 PM
flyry110's Avatar
Re: Re: hmmm.....
here ya go
http://gen3.4mg.com/
Ry
Old Nov 9, 2000 | 03:55 PM
Mike S.'s Avatar
I know...I'm not doubting you.....
I said...VG 5sp...read my post...yes, that does it in around 8-8.2 The 92se has the ve 5sp which is under 7 seconds to 60. My original post was to say that the VG auto is much quicker to 60 than 9.8.
Mike S.
Old Nov 9, 2000 | 05:19 PM
texasimports
Thanks for all the info. I'll have the specs up on the site very soon.
Thanks again
Old Nov 9, 2000 | 06:33 PM
James92SE's Avatar
2 VE's are better than one!
ve auto really does a 15.9? i thought it was in the 16's. guess that's good for me if thats true.
Old Nov 9, 2000 | 07:52 PM
Mike S.'s Avatar
hmmmm....I don't think they do.....
For whatever reasons the VE auto's are not that fast. Not trying to be a dork or anything I'm sure they are faster than the VG auto's but not by much. I guy near me in Ontario ran 16.8 with his stock VE auto. I think it was Glen S. A stock VG auto runs like 17 flat or so. I think Nismo87 said he saw a VG auto w/out air filter run like 16.89 or something.
Not sure why but the VE autos, from what I read, aren't all that much faster than the vg's.
Mike S.
Old Nov 9, 2000 | 08:05 PM
FAST4EN's Avatar
Re: hmmmm....I don't think they do.....
yeah it has a lot to do with the VERY tall gearing on the auto VE's maximas compared to any of the 5speeds or the VG auto.
tcb_02_max
Sep 11, 2015 12:23 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Supragte
Aug 12, 2015 10:00 PM
Team STILLEN
Aug 10, 2015 04:29 PM
