Cleaning VE engine bay
Old Apr 14, 2011 | 11:51 AM
-ReLLiK-'s Avatar
Its finally getting nice out and Its time for a full spring clean. When I had my 91 VG all I did was remove the battery and cover the fuse box, sprayed Meguiar's Engine Cleaner, and sprayed it off.
Other than those things, what should be covered/removed on a VE? Not trying to spray it off and something like the coil packs go bad because of moisture etc.
Old Apr 14, 2011 | 07:08 PM
BenStoked's Avatar
Jesus was a Zombie.
Greeny just covered the filter (iirc) with a a bag, and hosed his VE down, cleaned it, and hit it with a leaf blower.
I would advise doing it with the engine cold, so stuff doesn't crack due to sudden contraction from cold water.
it'll be fine, or expose a preexisting problem.
Old Apr 14, 2011 | 07:42 PM
chrome91's Avatar
if you want to powerwash, wait until the engine cools down and use a warm water wash and cover the filter and any exposed wiring elements
personally i wouldnt, i know some spray without covering anything but at the same time Jassics sprayed his 2nd gen engine bay and got a bad misifiring problem after and others have had similar problems
all i did was get a degreaser and use a toothbrush to scrub everything and wipe where i cleaned with a wet cloth afterwards, takes a few hours but its better imo
Old Apr 14, 2011 | 08:15 PM
Pearl93VE's Avatar
I can has?
Cool Engine. Walmart bags over battery/fuses/air filter. Put a spooge of dielectric grease in all of the electrical connectors that will get wet. Use a leaf blower or compressor to dry. Dry everything else (if any) with a towel and let the car sit a couple of hours.
I think patience is what pays off here. Don't just blast it out at the spray-it-yourself car wash while the car is hot then drive off. Do it when you know you won't be going anywhere and put a little bit of time into it and you won't have any problems. Done many cars without issue.
6spd4dsc
Mar 4, 2016 05:19 PM
Maximan190
Dec 16, 2015 06:01 AM
fastcarny
Oct 6, 2015 10:42 AM
aminus21
Sep 12, 2015 04:53 PM
03VQMAX
Sep 5, 2015 03:47 PM
