HUD conversion
HUD conversion
I have a couple of questions regarding a HUD conversion with analog gauges.
I have been running some tests on the HUD I have and found it is quite a bit out of calibration, my analog gauge lines up fairly well with the speed shown in a GPS/SatNav, but the HUD reads fast. Approx 60km/h when the analog gauge and GPS shows 55km/h. Is there any way of calibrating the digital control unit? I noticed there is several jumpers near the processor on the control board, that uses soldered on links, they are labeled J1 - J4, but J4 appears to have been removed, does anyone know what these are for?
Also, where have others mounted the control unit when keeping the Analog gauges? as they won't fit behind the speedo cluster like it does on the digital cluster.
Does anyone know if the HUD was ever fitted to a RHD Maxima? As I can forsee a battle to get the HUD cover to fit when mounted on the right side of the car.
the control unit mounts to the back of the digital display
when you cut for the HUD you can cut a little more out and fit in in behind your analog gauges, i wrapped mine with a piece of cardboard i believe but never had a problem with it
I still haven't figured out how to calibrate this unit, it appears to be out by an absolute figure, as at 100km/h it also reads about 5km/h fast.
I have found a few devices that you can fit in the speedo signal circuit to offset the signal, they are designed to correct the speedo when larger tyres or different differential ratios are fitted, but they offset by a percentage, not a absolute value.
I am putting off installing the HUD for now, as I know I won't look at it if it isn't accurite.
I also found the jumpers appear to set the default 'power on' status of the HUD settings, (ie. does it default to HUD on, KM/H or MPH).
all he has to do is place a rectangular piece of tint (maybe 30%) above the hud on the windshield. that will make the visual easier to see and get rid of the seeing double effect due to the reading hitting both the inner and outer sides of the windshield
sonic, theres a member on this board named Hectic if he chimes in he should be able to help as he knows a lot about the digital dash/hud
other than that since people are looking for other information im gonna post the HUD only write-up that you cant find on his page anymore
you guys can thank Craig Brace
Parts you'll need:
HUD display and trim piece
main control unit
wiring from HUD to main control unit
main harness going into the center of the control unit
brown 7 wire harness going out of side of control unit (6 white wires, 1 black wire)
Getting the parts:
I got my parts from a local junkyard all for about $60. If you tried to get it from a dealer, I'm sure it would be several hundred dollars at least. Depending on the junkyard, you may have to buy the whole digital gauge assembly since they probably wont want you taking pieces out of it. It took me a while to find a junkyard that actually had the parts. Also, the digital dash is prone to failing. I'm not sure whether it's the brain unit that fails or just the gauge display. I have heard many people repair these by resoldering the circuit boards so that would be a good idea to do before the unit is put in.
Remove the gauges (check out my clock fix page if you need instructions for that, then it's just 4 more screws holding the gauges in place). As you pull the gauges away from the dash, there will be several large harnesses holding it in place. Each one has a clip in the middle that you push in while pulling the harness to remove it.
With the gauges out, you will need to remove the control unit from the back of the gauges. I can't remember for sure exactly how it's connected, but I know there were a couple screws and a couple harnesses to unplug. The unit looks like this:
pic
You need to get the large harness that goes to the middle connector on the control unit. It has 20 wires going into it. Cut it with as much wire slack as you can get (you'll probably still end up having to extend a couple wires though). Also, you'll need the brown harness that comes out of the side of the control unit that has 6 white wires and 1 black wire. This goes to the ON/OFF and MPH/KMH buttons. I just cut the harness (but left enough wire so that I could splice new wires onto the end of it).
Now remove the hud display and it's trim piece from the upper dash. The trim piece has two clips on the side closer to the steering wheel and one on the side closer to the windshield. Use a flathead screwdriver to carefully pry up the trim piece from the dash. You will now see three phillips screws holding the display to the dash. Remove these screws - I found a right angle screwdriver was the easiest thing to get in there. Now pull out the hud unit and the wiring for it (should already be unplugged from the control unit). You'll also want to keep the screws and clips that are used to mount the hud display.
Installation:
Remove your entire dash! This is a lot of work, but not that hard. You'll need to remove the radio trim, the gauge surround, steering wheel column plastic, cruise/defrost/dimmer/fogs surround, lower drivers side dash, glove box, piece around the glove box, plastic around the radio trim and climate control, both A pillars, defrost vents, upper triangle vents, and sunload sensor (if you have auto climate control). There are lots of screws holding these pieces on, just look around and you should be able to find most of them - some have covers that you need to open with a flathead screwdriver first. After all that is removed, there are 2 nuts and 3 screws holding the main upper dash piece on. The screws are under the defrost vents and the nuts are at the bottom corners of the dash. There are also a couple clips taht hold wiring to the dash. As you pull it off, you'll see where it's holding and just unclip these. Here's a pic from the FSM that shows you all the different pieces and screw locations.
link
You might be able to get away with cutting the hole with the dash in the car, but there really isn't much room to work there with the windshield and the vents and wiring underneath. You could also pull the dash from the car where you got the HUD unit, but I didn't want to go through that hassle or pay for the dash at the junkyard.
Now you will need to cut the hole in your dash. I traced a template from the car at the junkyard and used that on my car and it turned out very nicely. I will scan it and put it up. I used an exacto knife to cut the top layer of material and then peeled that part off. Then I used a dremel to cut the plastic underneath that. The shape of the plastic hole is different than the shape you cut on the top layer - the plastic needs to come in at a few spots so you can put the screws there. After I made the hole, I test fit the HUD display several times and then cut the plastic a little more to make it fit right. Cut a small hole first and slowly make it bigger since you cant go back if the hole is too big. I then drilled the holes in the plastic to mount the screws.
Once the hole is ready, the whole dash can go back in place and you just need to focus on wiring. On the small brown harness coming from the side of the main control board, you will need to extend several wires from there. If you look at the wires, the black/ground wire is in the 7th position. The wire in the 4th spot is for MPH. The wire in the 5th spot is for the ON/OFF switch for the HUD. The wire in the 6th spot is for KMH.
The ON/OFF switch is just a toggle. If it is grounded and released, it will turn on. If you do that again, it turns off. The KMH and MPH are the same way, if you ground one of them, it will select that measurement. I just connected the MPH and ON/OFF wires together and then extended that wire to another switch in the car and the other side of that switch is ground (I used my power/comfort switch since I'm 5spd and it doesn't affect my tranny, you can add a switch anywhere or do something else creative).
Now you will need to connect all the wiring to the large harness in the middle of the main control unit.
The following wires connect to the same color wire at the middle harness of the three going to the back of the analog gauges (find the same color wire in the existing harness and splice into it) :
Black (x2) - Ground
Green/Orange - Speed Sensor
Green* - Speed Sensor
*there are two solid green wires in the main control unit harness. This one is the one that is at the end of the harness, next to the green/orange wire.
The following wires connect to the same color wire at the dimmer switch harness :
Red/Yellow - illumination (parking light) power
Black/Red - illumination ground
Light Green/Black*
Light Green/Red
*there are two light green/black wires in the main control unit harness. This one is the one that is next to the light green/red wire.
The following wires are power, either constant, ACC or ON. There are many places to find these power wires. I just tapped into the wires behind the fuse box, but you can get power from the radio, climate control, security system, door lock timer, etc. Just use a test light and make sure it's correct.
White/Blue - ACC or ON
Brown/White - +12V constant
Green* - ON
I just connected the White/Blue and Green together and connected them to a wire that was only powered when key is in the ACC or ON position.
*there are two solid green wires in the main control unit harness. This one is the one that is second from the end with a blank spot on one side, a black wire on the other, and another blank spot below it.
The following wires are not used for the heads-up display. I just covered the ends of these and taped them up with electrical tape.
Light Blue - to ECU
Light Green/Black* - to ECU
Black/Green - temp sensor
Light Green - fuel level sensor
*there are two light green/black wires in the main control unit harness. This one is the one that is on the end of the harness and above the black wire.
You'll need to find somewhere to mount the unit. I ended up putting it just behind the gauges. I had to cut out a portion of the plastic behind the gauges and then there was a nice slot where I could drop it in. Be sure to cover the back side of the circuit board. It is not covered and if it were to touch ground (any metal on the chassis) it could ruin the board, blow fuses, melt wiring, or even start fires. I just used a piece of cardboard to cover the back of the unit and taped it on. I used zip ties to hold the whole unit in place. There are many different options of where and how to mount it. You may need to extend some wiring depending on where you locate it.
That's about it. Test it out before you put everything back together. If the unit does not come on, first test all the power signals and then check the ground switch to turn the unit ON (the brown harness going in to the side of the unit).
Good luck.
Parts you'll need:
main control unit
Getting the parts:
pic
Installation:
link
Black (x2) - Ground
Light Green/Black*
Light Green/Red
Green* - ON
Light Blue - to ECU
Good luck.
Now I reread it and see that your asking about HUD with analog cluster, I didn't even knew that was possible, have you taken the digital control unit apart from the digital cluster?
Regarding placement, maybe possible to lenghten the wires and mount it someplace else up there?
Since I wrote so much, didn't want to waste it:
I have installed the digital speedo, in 2 cars, the first one I just soldered the digital harness onto the analog one.
The second time (same speedo into new car) I thought it would be alot easier to swap it to newer cars if I had a harness for it, so I created an adapter harness..
I cut out the connectors from the analog one, added wires to it that I ran to a set of digital connectors, plus a few loose wires that is non-existant on the analog harness.
So next time I switch cars, I can install the digital dash in 10 min
But I still have a few bugs with it, quite a few of the indicator lamps are not working, so I'll have to do some troubleshooting some day, but speedo, rpm, temp and fuel is ok.
And remember you need the fuel sending unit to get correct fuel readings, analog one will be all wrong! I just grabbed the whole pump.
Also, if your digital speedo is showing you speeds when standing still (worse the colder it is), but shows correct when driving, you need to replace capacitors in the control unit. I replaced all of them - now it shows 0 when still.
According to other posts, you can use the HUD with the analog cluster, you just need the digital control unit to drive the HUD, I would do the whole digital cluster, but I don't have the cluster or the fuel sender unit. and I have heard they are quite rare.
The wiring harness could be extended to mount the control unit elsewhere, but I was thinking I could mount it behind dash moulding when I have the dash out to fit the HUD, the only problem is it will be in-accessable without removing the whole dash again.
[quote=sonicii;8025352]According to other posts, you can use the HUD with the analog cluster, you just need the digital control unit to drive the HUD, I would do the whole digital cluster, but I don't have the cluster or the fuel sender unit. and I have heard they are quite rare.
I've seen this done with the analog dash b4 by a few members on here alone. The digi dash is very rare and the digi fuel pump sending unit is even more rare. It took me a long time to find a digi sending unit for my Max, my digi sending unit ground wire terminal on the sending unit cap was unrepairable, so I had to replace it. The HUD looks cool with either dash cluster, normally I like the newer analog dashes but the 3rdgen Maxima digi cluster was done properly and that's why I haven't swapped it over. Everybody always comments on the HUD when they see the projection that looks like a hologram on the windshield.
I broke my FFFF'in HUD windshield!! Damn there expensive to buy brand new. Anywhere from 800-1400 just for the glass. I'm going to either run threw all the JY's or replace with a new regular windshield and put a piece of tint in it's place.
KabirUTA13
19
Oct 17, 2015 02:15 AM
Calabar
Oct 5, 2015 09:57 PM
Hdnseek
Sep 9, 2015 05:55 AM
