Problems I had while replacing knock sensor (VE)
Old Dec 21, 2011 | 06:18 PM
Laevateinn's Avatar
It's my first time doing this thing. So I've been working for a total of 12 hours now and I encountered a couple of stuff.
1. Does the KS connector only have 1 pin (KS to connector)?
2. Are the PCV hoses behind the IM really hard and not flexible?
3. Can I replace the brake vacuum hose with a hose of the same size but not the OEM part itself?
4. Are OEM fuel hoses different than cut to length hoses?
5. The connector for the smaller coolant temp sensor (flat connector) near the thermostat assembly is broken can I just hook the wire to the flat metal and put a heat shrink on it?
Old Dec 22, 2011 | 12:45 AM
maximo018's Avatar
1. Yes and I recommend replacing the sub-harness
2. only if its old
3.Yes
4. Yes because they are already pre-cut
5. Just go to the jy and snip another one and solder it on. Thats what I did.
mrc00l88
Jan 25, 2024 01:14 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
maxinout93
Aug 20, 2015 02:17 AM
