side mirror fuse location & sunroof question
Old Apr 28, 2012 | 10:07 AM
jona571's Avatar
side mirrors fuse location on my 92 SE and does anybody know if the sunroof comes out as easy as it looks 8 bolts and out it goes??
Old Apr 28, 2012 | 10:48 AM
DMad8724's Avatar
for the sunroof, you have to remove the oh **** handle support brackets, and then the whole assembly drops down after you unbolt it. it is also connect to a drainage tube at each corner.
the mirror fuse should be the 4th one up from the bottom on the right side 10A AIR CON
Old Apr 28, 2012 | 01:40 PM
jona571's Avatar
great thank you so much
Old Apr 28, 2012 | 05:22 PM
Hectic's Avatar
David: Don't help this guy, he deletes threads and subsequent posts after he gets his answers.
Old Apr 30, 2012 | 12:57 AM
maximagician's Avatar
is it leaking?,test the drains,pour water in the open roofs gutter and look for it draining
behind each wheel,usually its the right rear which has a junction with the power antenna drain that clogs
Old May 6, 2012 | 10:25 PM
jona571's Avatar
thanks for the help,,my sunroof is cracked so I need to replace it
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
