Getting back on the road after 1.5 years problems...
Old May 12, 2012 | 11:25 PM
Infam0usMax's Avatar
After 1.5 years im getting her back on the road... why? you gotta love the 3rd gen... anyways having some trouble... I have a list of things I need help with:
the car is now running...
1. My car is running on 4 cylinders... the two that's on the pass side of the car are not working... yes they are getting fire to them...
2. When you turn the key twice all doors are suppose to unlock... they stopped hear the timer clicking behind the dash the relay must be stuck? went to they jy and the 91 is completely different when it comes to that...
3 the problem that is really getting on my nerves... my battery keeps dieing i have two of them ill charge one and then put the other one it but they dont hold their charge one of them is a optima red top and they other is a interstate...
my dad ran a check on it and there is something that pulling 1.3 amp from the batt when car is off... but i doubt thats enough to kill the battery... what could be the cause of this?
Old May 13, 2012 | 06:36 PM
chrome91's Avatar
- only running on 4 cylinders most likely means you have 2 bad injectors
- door lock problem may be the door lock timer, does the keypad under your door handle unlock the doors?
- if the battery's are good and holding a charge it has to be the parasitic draw draining them
Old May 13, 2012 | 11:13 PM
What sup Chrome... long time no see...
-go ahead and just replace the two?
-i never had the code for the keypad but it does light up and when u push any number it beeps light its suppose to
-good news on the battery the optima does hold a charge now...
Old May 14, 2012 | 07:13 AM
chrome91's Avatar
not saying its 100% the injectors, run a few more tests. but most likely being a VG its the injectors
when my door lock timer crapped out, the keypad would still open the trunk and windows but not the door locks. the door lock/unlock buttons inside wouldnt work either. had to use the key to get in and manually unlock or lock the doors from the inside. if your buttons inside dont lock/unlock the doors its probably the timer, if they do work its something else
Old May 14, 2012 | 09:42 AM
shiloh51933's Avatar
Are you getting good spark at those 2 cylinders? Have you checked the resistance of those 2 injectors and check the injector connectors/hareness.
Old May 15, 2012 | 03:40 AM
maximagician's Avatar
do you mean 1.3 *VOLTS*when off?
i have read of a test for drain is to
try pulling fuses one at a time and see if the draw stops on a certain one,
but on newer cars i guess certain circuits will have some power draw so
this test may be false,heads up
Old May 15, 2012 | 05:38 AM
89Vg30Elover's Avatar
Parasitic draws can take a long time to find. I used to have one on my old Pontiac bonniville and it took me almost a month to find that the wire inside my door that went to the lite key ring holes for the car was the culprit. The fuse test for our cars maybe an ok way to do it, but my guess is that if he is having an issue with the doors like that he may want to do like I am doing now and remove the dash slowly but surely. I have a ground problem in my dash maybe behind the aftermarket stereo someone messed up. I have all the diagrams, I bought both the wiring book and the nissan factory book and I am doing research on what all those issues I am having are. If I come across anything else that may help with that I will let you know. As far as the injectors or only firing on 4 cylinders, any local autozone has a loaner tool for injectors. its a noid light tester, Im not sure if it will do nissans but like dude said, check for resistance, or the only other way to check if they are working is to pull the rail and hook the injectors back up and see if they shoot fuel, but at that much effort miswell replace them. Check the connectors to the injectors too, I had to replace a couple when I did my head gaskets because they got brittle and broke. If its a connector then you dont have enough juice going to the injector.
Old May 16, 2012 | 01:22 AM
My bad yes I mean to say 1.3 VOLTS
pulling fuses sounds like a good idea but they optima battery hold a charge now... so batt prob is fixed... still dont know what it was but i will have him check to see if its still pull that.
Old May 16, 2012 | 01:26 AM
yeah thats how he knew it was not the connectors/harness im guess its bad injectors im gonna full her up and add some injector cleaner to see if that does anything... the car has been sitting so is its possible they are stuck
Old May 16, 2012 | 06:49 AM
Kountz430's Avatar
bald aggression est 78
makes me wanna run my g35's again
Old Jun 9, 2012 | 11:22 PM
I need a door lock timer for a 1992 GXE ASAP.... who had one...
Old Jun 11, 2012 | 06:23 PM
chrome91's Avatar
whats wrong with it, IIRC its just one wire that fricks up in the unit and you have to solder it together
Old Jun 11, 2012 | 07:27 PM
maximo018's Avatar
I have 2. Let me know if you need them.
Old Jun 11, 2012 | 07:29 PM
maximo018's Avatar
Really. Which one?
Old Jun 11, 2012 | 07:37 PM
James92SE's Avatar
2 VE's are better than one!
There are no wires on the door lock timer it's a just big circuit board essentially. You have to resolder a bunch of the joints because they crack, which is what causes them to fail. I've only had mixed results with this and it's incredibly tedious to resolder them
Old Jun 11, 2012 | 07:42 PM
chrome91's Avatar
my bad im thinking about something else with wires then, knew there was soldering involved lol
Old Jun 14, 2012 | 01:30 PM
lol that sucks im just tired of having to get in the car and unlock the other three doors... @Maximo do they work?
Another question...
How hard is it to add a keyless entry system?
Old Jun 14, 2012 | 08:42 PM
maximo018's Avatar
Another question...
Last I checked a year ago. I thought I had a similar issue but it turns out its my driver door lock (in the door). Its intermittent so I'm not real aggravated yet.
JRod28
Dec 29, 2023 09:56 PM
tsi6001
Oct 3, 2022 10:23 PM
deezo
Aug 16, 2015 06:21 PM
ramtin325i
Aug 8, 2015 05:13 PM
laparka66
Aug 6, 2015 09:36 AM
