93 maxima is killing me
Old Jul 7, 2012 | 03:07 PM
raun31's Avatar
My 93 maximal has been givIng me problems to the point where I wana jus get rid of it......my problem is my car just started to crank without starting fluid thanks to a new tps sensor I bought also I bought new fuel pump n filter and now my car still won't drive when I floor the gas pedal or jus drive....it only drives bout 20 mph and I don't wat else to do I put several maf sensor on it and I really need some help
Old Jul 7, 2012 | 05:55 PM
maximo018's Avatar
1st off do you have a VE or VG? Is it auto or m/t? Have you ohmed out the MAF, tps and other sensors you bought? Have you done something as simple as check ohms of the coilpacks? Alot of times when this happens ppl go off on wild goose chases spending money & chasing their tails to circle back to find out that the coilpacks were the culprit. Your having the exact same thing happen to you thats happening to me. (Hard as hell trying to start from a dead stop in 1st. When you get it finally going after giving it a $hit load of gas it only wants to go up to 20mph no more) try the coil packs first.
Old Jul 7, 2012 | 06:23 PM
raun31's Avatar
It's. VG and a automatic
Old Jul 7, 2012 | 07:17 PM
maximo018's Avatar
Ok u don't have coilpacks. Have you check your distb? When were the plugs/wires last changed? Whats the condition of the distb cap? If you replaced the tps with a reputable replacement then the only other thing I could think of this being is either a MAF issue or a ignition timing (spark) issue. It wants to go but something is holding it back. Oh wait you got an autotragic. Nm everything else for right now. Does it idle fine? If so replace that tcu (transmission ctrl unit) and see what happens.
Old Jul 7, 2012 | 08:31 PM
Chris Gregg's Avatar
Get Off My Lawn
I wouldn't recommend jumping into a tcu at this point, but if you find you need one, I probably got one.
Give us some more info about idling, so it starts without throttle and idles fine? About 1k rpms when cold and drops to 800 after warmup?
When in park, can you rev the engine? Does it rev smoothly or stumble at all? Does it rev quickly or drag out till redline?
Anything you can give us will help. Even a video can do wonders.
Old Jul 7, 2012 | 08:43 PM
raun31's Avatar
Ok when I first start it up it stumble til I keep giving it some gas and then it clears out n idle fine....but when in park I can rev it engine all the way no problem but when in drive or reverse I cant get it to move far its like driving Mrs daisy in the neighborhood
Old Jul 7, 2012 | 10:00 PM
maximo018's Avatar
Would this be a bad or loose ground issue?
Old Jul 7, 2012 | 10:34 PM
chrome91's Avatar
had the same thing on my Supra, coil wasnt giving enough spark and the distributor cap was cracked and that fixed it. see how much spark youre getting, if youre getting weak spark thats at least a start
Old Jul 8, 2012 | 08:56 AM
Get Off My Lawn
Although there may be more than on issue occurring here, and there is going to have to be a process of things to run through, I'm goin to throw out something very simple to start out.
I highly suggest you take a listen while the engine is running for any hissing sounds. What you are describing sounds like possibly a vacuum leak. The VG is highly susceptible to broken lines, and even a tiny leak will result in hard starts and power issues.
Start listening for a his and
Track it down. Inspect the lines running to the heater valve on the fire wall. Check those lines that run beneath your throttle body and the one beside tha IACV.
From there, you need to check spark, look at fuel pressure, etc.
We are assuming your maintenance is up to date as well, correct?
Old Jul 8, 2012 | 09:10 AM
shiloh51933's Avatar
Have you checked to see what the fuel pressure is at on idle/throttle? I believe the VG block is 36psi on idle and 42psi on throttle. If you don't have a fuel pressure gauge, I believe Harbor Freight has them for a good price.
Old Jul 8, 2012 | 10:24 AM
Get Off My Lawn
+1 on Harbor Freight pressure tester.
Old Jul 8, 2012 | 10:53 AM
road_warrior05's Avatar
I started having the same problem with my auto VG yesterday. Only on warm-engine starts does it idle rouh and stuggle to accelerate. but if I push on the throttle for about 30sec, it'll clear up and run fine.
Old Jul 8, 2012 | 12:05 PM
Read this thread carefully and follow the suggestions made to OP, Air/Fuel/Spark.
Balkins
Feb 1, 2016 12:45 AM
Goffery2uned
Aug 21, 2015 09:50 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
