2 questions
Old Jan 9, 2002 | 10:31 AM
JNFBVZ
2 questions
We recently bought a 93 max from a family member and are having 2 problems.
1. When we got the car, the family member did not have the code for the keyless entry. Does anyone know where I can get that code?
2. We bought a remote start with the capability to lock and unlock the doors and pop the trunk, but we can not find a wiring scematic to know which wire goes to what in the door. Does anyone have a wiring guide?
Thanks for the help!!!
Janette & Brent
Old Jan 9, 2002 | 10:34 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
1.) http://www.kalebonline.com/maxima/tutorials/faq.html
2.) try to pick up a factory service manual. all the wiring schematics you need will be in there... check out ebay for one
Old Jan 9, 2002 | 10:54 AM
nupe500's Avatar
Jedi Knight
Um....
I would do what Chris said and also I think that the wiring necessary for door operation is under the passenger side kick panel, however, I don't know what is what. I noticed that when I was having my alarm put it they were predominatly working on that side not the drivers.
Old Jan 9, 2002 | 10:56 AM
Matt93SE's Avatar
STFU n00b!
both of these questions are answered in the FAq pages on this board..
the stuff for your door locks can be found on my website (also linked in the FAQs)
www.ee.utulsa.edu/~mblehm/faq/wiring_info/
go to the alarm info, then click on the 93 files and print them out. I've installed two alarms on 93s using these pages, so I will verify they're correct.
Old Jan 10, 2002 | 12:49 PM
mo90gxe's Avatar
Re: 2 questions
Janette & Brent
Ok first get a flashlight and, if your back is stiff, someone more flexible. Open the front passenger door and slide the seat back. Get on your back and with the flash light, look up under the dash, toward your left (this would be on the door's side of the dash). You should see a brass colored box with a wire harness and wires attached to it. You might see a label that says "Digital Touch Entry Control Unit" or something like that. You should also see two or three lines of code on the label. One of the lines should begin with the letter "S". Record the last 7 NUMBERS on that line, that's the master key number (well it should be).
Now, wiggle out of the car and shut the door. Press the button labeled "C"/"ST", where "C" is on the top and "ST" is on the bottom. Now enter the seven digit master key and you should hear a constant tone sound, during this period, enter a 5 to 7 digit entry key, this cannot match the master key. There also cannot be three digits in a row that use the same button, I.E. 909xxx or something like that. After you've entered the code, wait for the tone to stop, press "LCK"/"9|0" to lock the doors (HAVE A KEY READY JUST IN CASE YOUR CODE DOESN'T WORK STUPID!). Now press "C"/"ST" and enter your new code, the doors should unlock, if the doors do not unlock, press the "WDW"/"5|6" key and see if your front windows roll down. If they don't, the code operation didn't work, give me an email or something. If it did, then your door lock timer is fried and you need a new one. You might want to email me on that one too!
good luck
Old Jan 10, 2002 | 12:51 PM
JNFBVZ
Re: Re: 2 questions
Thank you all for your help!!!!!
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
