Damn interior lights don't work anymore
Old Dec 5, 2012 | 03:31 PM
TonyJr's Avatar
After I install the aftermarket head unit my dimmer stop working and dash stop working. Y it that happen? Please help.
Old Dec 5, 2012 | 03:40 PM
tigersharkdude's Avatar
Please refrain from using profanity in your thread title.
You likely popped a fuse, or left your dimmer switch unplugged
Old Dec 5, 2012 | 04:02 PM
TonyJr's Avatar
Sorry lol I really didn't think it was that bad at all. But negative on all your suggestion. Everything seem ok but when I took the power cable from the headunit and connect it together with the black n red strip cable ( interior lighting wire) the dash come on but when I turn on the headlights the dash lights go off.
Old Dec 5, 2012 | 08:35 PM
Amerikaner83's Avatar
you miswired something
Old Dec 5, 2012 | 09:12 PM
DennisMik's Avatar
There are 2 black/red stripe wires in the radio connectors. One is for the dash lights, the other for a speaker. What is the signal name of the radio wire you connected to the black/red stripe wire. Are you splicing wires directly to the nissan wire harness or do you have an adapter such as a Metra kit?
Old Dec 6, 2012 | 12:44 AM
TonyJr's Avatar
Its my fault. Because I was inpatient to install my headunit I decided not to wait to buy the harness for the radio and cut the factory harness and just tap in all the lines. It dorked but it was a mess. That's when everything started to go wrong, I found the factory plug at a junkyard , so I repair it back. But still having the no dash light problem
Old Dec 6, 2012 | 12:46 AM
TonyJr's Avatar
I bought a adapter at walmart. I did see the wire and I tap it in Ruth power wire and the dash comes on but when I turn on the headlights it turns off.
Old Dec 6, 2012 | 12:47 AM
TonyJr's Avatar
My car came with Bose factory system.
Old Dec 6, 2012 | 04:36 AM
DMad8724's Avatar
If its not a fuse/loose wire then it sounds to me like you fried your TCU (time control unit)
not hard to replace its under the panel below the steering wheel
Old Dec 6, 2012 | 05:50 AM
TonyJr's Avatar
Replace it yesterday. Tcu
Old Dec 6, 2012 | 05:51 AM
TonyJr's Avatar
Where is fuse #40?
Old Dec 6, 2012 | 07:54 AM
Originally Posted by TonyJr
Where is fuse #40?
fuse box to the left of the driver's knee...iirc it's a 7.5A (red) but don't quote me.
Old Dec 6, 2012 | 09:40 AM
TonyJr's Avatar
Is it for 4th only . Because I don't see it
Old Dec 6, 2012 | 10:39 AM
TonyJr's Avatar
4th gen maxima
Old Dec 6, 2012 | 11:44 AM
DanNY's Avatar
Ad·min·is·tra·tor
what are you using exactly to connect/splice the wires?
worse case disconnect your mess that you created and see if the lights go back on.
Old Dec 6, 2012 | 02:49 PM
TonyJr's Avatar
That is smart thinking. I'll start all over by disconnecting all wires. And fix the dash lights, then I'll start to connect wires one by one.
Old Dec 7, 2012 | 06:50 PM
maximo018's Avatar
Was battery hooked up while all this? If so something touched something else and shorted it out. Check wiring for the hu and fuses.
Old Dec 8, 2012 | 06:31 AM
TonyJr's Avatar
Ok thanks I just bought a multimeter to fine the short. And I do remember tapping two wires together and there was a spark. Smh
Old Dec 11, 2012 | 01:03 AM
maximagician's Avatar
one of the factory stereo wires controls the dimming on the factory stereo,maybe you goofed it somehow?i think its red with an orange or yellow stripe
Tbone3944
Sep 29, 2015 09:04 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
kenc15
Aug 5, 2015 08:29 AM
