Can I get the keypad code?
Old Jan 11, 2002 | 04:24 PM
monkeyboy's Avatar
I recently purchased a 3G Maxima, and was wondering if it is possible to the the keypad code for it? Is this something a Nissan dealer has access to?
Second question: How hard is it to install either keyless entry or an alarm w/ keyless entry? I looked on Crutchfields site, and they say they have adapters to simply plug an alarm in, for certain cars. Is this one of them? I am finding it hard to get used to the doors unlocking everytime a door is closed. Even if I do remember to lift the handle, usually one of my passangers will close their door after me.
If I could get the door lock thing taken care of, I will be set. I have so far tinted the windows, and am in the process of replacing the bose stereo.
Thanks.
Old Jan 11, 2002 | 04:30 PM
Maxima NutBag's Avatar
Try this site's advice. It tells how to access your keypad code, and it's easier than you think.
(Tutorial From http://www.kalebonline.com/maxima/)
My Maxima has the keyless Digital Touch Entry System, but I don't know the code. How do I set it and operate it?
Ok first get a flashlight and, if your back is stiff, someone more flexible. Open the front passenger door and slide the seat back. Get on your back and with the flash light, look up under the dash, toward your left (this would be on the door's side of the dash). You should see a brass colored box with a wire harness and wires attached to it. You might see a label that says "Digital Touch Entry Control Unit" or something like that. You should also see two or three lines of code on the label. One of the lines should begin with the letter "S". Record the last 7 NUMBERS on that line, that's the master key number (well it should be).
Now, wiggle out of the car and shut the door. Press the button labeled "C"/"ST", where "C" is on the top and "ST" is on the bottom. Now enter the seven digit master key and you should hear a constant tone sound, during this period, enter a 5 to 7 digit entry key, this cannot match the master key. There also cannot be three digits in a row that use the same button, I.E. 909xxx or something like that. After you've entered the code, wait for the tone to stop, press "LCK"/"9|0" to lock the doors (HAVE A KEY READY JUST IN CASE YOUR CODE DOESN'T WORK STUPID!). Now press "C"/"ST" and enter your new code, the doors should unlock, if the doors do not unlock, press the "WDW"/"5|6" key and see if your front windows roll down. If they don't, the code operation didn't work, give me an email or something. If it did, then your door lock timer is fried and you need a new one. You might want to email me on that one too!
Old Jan 11, 2002 | 07:34 PM
monkeyboy's Avatar
Thanks! Exactly what I wanted to hear. No dealer to deal with or anything.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
