Sputtering VG30e, but Tach Remains Steady
Old Mar 30, 2013 | 12:17 PM
La Zona Imagery's Avatar
I just recently noticed a slight "sputtering" issues on my '91 SE. It sputters on idle as well as acceleration. Not a huge issue, but annoying. The thing is, the tachometer remains steady...it does not fluctuate with the sputtering.
Wouldn't a faulty fuel injector result in a fluttering tach?
Any ideas?
Old Mar 30, 2013 | 03:56 PM
Greeny's Avatar
¯\(°_o)/¯
ignore the tach, it's not any more accurate than the fuel gauge lol....do all the standard tests...ohm the injectors, check the plugs and wires, yada yada.....
Old Mar 30, 2013 | 04:53 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
It would take a HUGE arhythmic sputter (ie spark cut or fuel cut, not just a rhythmic sputter from a failed fuel injector) to show up on the tach while. Especially when the car is moving, you have the weight of the rotating assembly AND the momentum of the entire vehicle keeping everything stable.. moreso on a manual than an automatic. I can see a MAF issue causing enough disruption to cause a tach-visible sputter.. just not an injector problem.
Old Mar 30, 2013 | 09:07 PM
thanks for the tips guys!
Old Apr 3, 2013 | 12:47 AM
ok one of my injectors is getting a reading in the 38-40 ohm range...all the others read 13 or 14 ohms
Old Apr 3, 2013 | 02:43 AM
Greeny's Avatar
¯\(°_o)/¯
Well, "there's yur trouble"...you can replace that one or all of them...If you are interested, I have for sale a entire set of injectors still in the rails..all of them ohm out perfect
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
